I cant delete it :( i was just merely saying u might get a job there with thise "deadly" skills lol..
Lol dont stress man, like i said you would have to be unlucky to get a report on it BUT naming names etc is a touchy subject ;)
Yer thats fair enough :) my biggest downfall i dont think before i yap :P
Lolz, dont worry i do the same! You get a window to "edit" your post once its up! If you say something and think it was too much you can always get a mod to delete or edit it for you!
Pretty good forum, better than ones i have been on in the past that is for sure!
Now get some pics up of this thing you are building?
For sure im away in sydney on hollidays but as soon as im home pics will be up fo sure :)
If its something you have taken progress photos of and will continue to do then you can start a build thread on here too!
If not, just post em up in here so we can have a look :yes:
Lol build me a low line trailer! Pm me a price man! Am serious lol.
as for Pitts that's who I would have recommended for sure! Seen quality no nonsense results from them and am told the guy is a champ too
My 33 gtst makes 330rwkw with a gt3582r. Starts to build boost around 3500rpm, once it hits 4000rpm is when it sits you back in your seat. Mine made that at 20psi. The boost curve on the dyno printout I have is a bit stuttery but it feels like it holds boost perfectly when youre driving it, i think its since been fixed (its a year old and from previous owner). It has a 38mm turbosmart ultragate, ide go 45mm if I was building it as they seem to not have as much issues with lower boost because they are a larger gate.
  • Like 1
Is that on pump fuel?
Yeah Pump 98.
Some more info:
Standard motor, 750cc Siemens injectors, custom fuel rail, bosch 044 & warlbro 255(intank). Power FC
These turbos can produce huge numbers. If youre just seeking 300kw-ish go for a gt3076r. You can make that power and have more response.
p.s. I have heard mixed reviews about Slide Industry turbos. Let your tuner know its not a Garrett as they might just assume. Just passing on what ive read not bagging the brand or trying to start a cuffufle lol.
Edited by Bennis
Don't you go picking on the lil 3076 Mr Bennis, I made 35r numbers with mine with epic response hehe....
Actually, can you send me your dyno sheet when u get a chance?
I was actually trying to talk up the 3076r, you know I want one!! haha
Ill find a pic, there was one the seller gave me.
Here we are, as you can see its a fair bit more laggy then your 3076r results.
cp4979387782421508755.jpg?height=700&asp
Looks like a tad over 23psi man :yes:
Pros and cons on slide industry turbos kgo :)
They are just Chinese copies... So why bother?
If you are on a budget - Hypergear or Kando. If you want better performance then the Garretts and more recently the HTA/FP items are becoming quite popular now results are coming out
Lol... Good to see you following the trend Mr Ash... Only 2 of us running them on a 25 so far that I know of and both just shy of 400kw with super response :yes:
    • Big R34 GTR parts cleanout. I have a lot of stuff collected over the last 14 years and my missus is giving me hard time. Make my life easy.   Nismo GT carbon fibre diffuser fins (discontinued)  NEW  $2900 Garage Defend Stingray canards carbon fibre  NEW  $1300  Top Secret G Force carbon fibre front diffuser  NEW  $2000  Haltech Elite 2500  NEW  $2500  Haltech Platinum Pro R34 GTR   USED  $1400  Apex’I power FC D'jetro + hand controller R34 GTR   USED  $1400  Nissan OEM BNR34 ECU  USED   $1000  HKS EVC 6  USED  $600  Blitz dual SBC ID boost controller.  USED  $350  TRE 255 LPH Fuel pump  NEW  $100  Fujitsubo  Super Ti exhaust  USED  $2700  Tomei Expreme Ti exhaust  USED  $2000  Trust stainless steel front pipe  USED  $1000  Apex’I super suction kit  USED $400  BC BR coilovers  USED  $600  Hardrace front upper camber kit. USED  $300  Garret 2860-5 turbos –  one good, one needs reco USED  $1000  Nissan OEM Toshiba MFD Screen replacement  NEW  $450  Nissan OEM BNR34 Series II front passenger seat  USED (mint) $5000   Nissan OEM BNR34 front bar in TV2  USED  $1000  Nissan OEM BNR34 front lower air spoiler  USED  $900  Nissan OEM BNR34 front lower air spoiler (painted)  USED  $900  Nismo front indicator (clear) USED  $80 Nissan OEM BNR34 radiator  USED $500  Nissan OEM BNR34 turbos  USED  $500  Nissan OEM BNR34 intercooler USED  $800  Nissan OEM BNR34 front swaybar   USED  $500  Nissan OEM BNR34 intake pipes   USED  $400    Also have a square set of uber rare Volk CE28n in 19*10 +22. Not really keen to sell these but make a high enough offer and maybe I will. If you don't know how much these usually sell for don't bother.   PM for pics.  Pickup Chadstone VIC or postage at buyer's expense.
    • Thanks Mate, I did know you could do that but i know there is a pump out there that you can bolt on and it all lines up. I was told about it and then forgot the model, I figure if i am pulling it apart i will just put a new one on
    • You can also remove the veins from the HICAS portion of your existing pump.
    • Trying to swap the rear subframe on my R34 and can't remove the L-shaped stay brackets between the front subframe mounts and the sill/chassis. I'm in the UK so rust is a problem. I've used loads of WD40 and then Tunap 103 for days beforehand. I backed off the bolts forward a bit, backward a bit repeatedly for ages to try and avoid snapping. They have all moved a few full turns. The one I've spent most time on has come loose and I can turn with fingers, and it will pull down and push up 2-3mm. But it won't come out. I can tighten it back up and loosen it off again repeatedly but it still won't come out. I assumed there's a captive nut inside but if that's broken loose then I can't understand why I can always tighten the bolt back up - I'd expect it to just spin both ways. Any ideas what's happening here? I can't visualise what's inside there to cause this.
    • Cheers, yeah it was recently imported, is the actual Nissan not an Infiniti so will have to do some chasing around for parts.    Any ideas if the side skirts from a Q50 would fit on the 400r?
