Hey guys,
Over the next couple of months, I will be replacing various parts on my V35. Therefore, the stock counterparts will be up for grabs as listed below.
- Front bumper with aftermarket lip. Some scratches evident.
- Stock side skirts. Some scratches evident
- Non-brembo calipers + rotors + lines
- ?Brembo rotors
Open to offers on all the above
Body parts are painted black
Items located in Melbourne
Patience is requested from future buyers as I will be offloading these items as their after market counterparts arrive in the country.
Other items for sale;
1)
946921_10200743058691572_1611716823_n.jp
Brand: SSR
Model: MS1
Tyres: 225/35/19f 235/35/19r
Pair / Set: set
PCD: 5x114.3
Diameter / Width / Offset: 19x9.5 +18f 19x10 +24r
Condition: Small gutter rash on the right rear wheel, 1x wheel cap slightly damaged, other small imperfections due to daily use. No hairline cracks.
Willing to Ship: At buyers expense
Price: $3000
Willing to Swap: No, but keen to see what you got. Negative offsets, only 19x10-11 inch wide!
2) JL 13W7 in ported box (not carpetted) and JL 1000/1v2 amplifer for sale!
Can throw in all cabling required. Items are not even 4 months old. Selling it as these were in my old car, and they will not obviously fit in the V35.
$1400 for both plus wiring plus FREE capcitor.
https://www.sau.com.au/forums/topic/427248-vic-fs-various-v35-coupe-parts/
Bumpppp
Front non brembo rotors. Plenty of meat left. Have not even been machined once! $140 for both
1013699_10200890590899785_1753052125_n.j
Non brembo rear rotors. Same as above. $100 for both
Brembo slotted rotors. Little bit of life left in them (Maybe one pad life left depending on which pad you use) $100
1017370_10200890590699780_742746163_n.jp
Stock non brembo calipers with pads $200
1012611_10200890592139816_1886984897_n.j
Might be interested in the non-brembo rear rotors. Any chance you can do me a favour and measure the distance from the outer edge of the rotor to the outer edge of the hub? I found out one of my rear rotors is too small the other day and just want to check what size these are before committing to buying. The one of mine that is too small is 55mm, the other is 60mm.
basically this.
I discovered the other day that one of my rear rotors is smaller than the other and the brake pad is overhanging the edge of the disk.
I didn't have time to remove the whole rotor to confirm the overall diameter, but was able to measure the figure shown in the pic, the small rotor had a measurement of 55mm, the rotor on the other side which looked correct was 60mm.
I've got the original rear rotors of my coupe in the shed, and just measured them at 55mm (actually closer to 54mm). Both have a small un-worn (is that even a word) strip around the outer rim, so the pads definitely weren't overhanging the rotor. Just to clarify, I have a 2003 premium coupe, and these were the standard (non-brembo) brakes. Were there different calipers on different years?
I'm not sure, but I guess they must be, mine is an 05 350GT sedan, the rotor on the left side is quite close to 60mm and the is only a small strip around the edge that is unworn, like yours. But the pads on the right rotor overhang by about 3-4mm, which suggests the right rotor has been replaced with one for a different year/spec, but I can't find anything to suggest there are any differences, other than the brembos.
The Callipers and the pads on both sides look identical, so I am assuming it is just this rotor that is wrong and not everything except this rotor??
Thanks for checking though!
If it helps - my rotors are 292mm diameter & 16mm thick. The calipers have "15" & "4306" cast next to the bleed nipple, and "27A" cast above where the pads sit. I've got a full set of F&R rotors & calipers in the shed, so if you want any measurements or pics let me know.
Thanks for your help.. I actually created a new thread about this issue on the weekend.. I might post some further info in there if you are interested, instead of clogging up this 'for sale' thread.
Edited by sonicii
    • Um.... This is not easy. I will have a fiddle with it, but make no promises. I think, given the explicit resistances vs temperature, and your ECU measured voltages, it should be possible to match them up. I will do that by assuming a 5V supply from ECU to sensor, find out how much current would have to flow to produce that voltage, then use that current as a .... nah f**k. That won't work. The supply voltage is fixed, but there's nothing to say that the ECU regulates the current too. Um... I dunno. I guess there's a voltage divider setup in the ECU. As in, there's another resistance between the ECU's sense terminal and ground. That way, as the sensor resistance changes, that's how they get a floating voltage that varies with the temperature, without having to control the current. Give me a minute or 3.
    • *that* is a question for chatgpt (or someone that understands maths....but I'd try chatty). Drop them the table and ask for the formula
    • Alright. Exhaust has been looked at, and booked in 'soon'. I'm not 100% convinced it's going to be as good as possible but I'm going to go with it anyway. If I get a reasonable thing that works for 10 years I mean that's twice as long as I've lived with the current one. I have a more pressing issue. I have fixed my MPVI3 (by buying a new one). Excellently, one can wire in analog 0-5v inputs to the ECU itself. I had wideband already via Serial so I also wired it in via the direct input. The idea being I can use the standalone logging without a laptop and have Wideband data in it. The other wire I thought I'd use oil temp. This is where I've gone crazy. HPTuners requires you to implement a formula so you know how much volts = how much temp. This seems relatively simple to me. However I cannot find the scale for this anywhere on the internet, nor decipher how to figure it out without removing the sensor from the car. All I know is that voltage actually goes up as temperature goes down. I am using the actual gauge, so I can see what the temp is. The signal wire has been branched off into the MPVI3. EXAMPLE: 2.68v = 58C 2.7 = 57C 2.74v = 56C 2.8V = 54C 3.06V = 49C 3.18V = 47C 3.37V = 43C I think the gauge is 50-150C. It may be more. It may be less, because I can't find it for the love of f**k. It appears all the information about the gauges I have has been scoured from the internet, but the sender is VDO 320.021 I believe the resistance chart is this How the f**k do I convert this to a voltage? Once I have a voltage... I then have to perform this transform of said voltage to show it in the scanner: https://www.hptuners.com/help/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm @GTSBoy you're probably my only hope here TEST YOUR MIGHT
    • Here’s the updated and installed muse replica nismo ones … very happy with the outcome. Eventhough I painted my whole rear end due to my rich idle lol.
    • Hmm. I had a good look (w/o searching, because I'm not logging in) and couldn't see it either. I distinctly recall the thread, not many weeks ago. It must have been removed or perhaps put into the back section. If it was in Off Topic you should at least have been able to search it up. So if I'm not hallucinating, it is fairly decently removed.
