  • Replies 67
SOLD:
Clutch Master Cylinder
Fuel Tank & Pump
Engine & Gearbox
Exhaust
Intercooler & Piping
Airbox
BOV's & Return
PS Pump
A/C Setup
Wheels
Brakes
Brake Air Ducts
Hubs
Struts
Lower & Upper Arms (Front)
Castor Rods
Sway Bars
Rear Driveshafts
Steering Column
Steering Rack
Strut Braces
Tailshaft
Rear Subframe
Underbody Bracing (Rear)
Diff
Atessa Pump & ECU
Relay/Fuse Box
Boot Trims, Plastics, & Carpet
Boot/Fuel Release Cable
Locks & Keys
Spare Tyre
Jack & Mount
Series 3 Xenons
Front Lip
Front Grille
Front Indicators
GTR Wing
Sideskirts
Side Mirrors
Fuel Cap Flap
Bar Skin (Rear)
Bonnet Lining
Guard Lining
Antenna
Seats
Seatbelt (Driver)
Steering Wheel
Instrument Cluster
Sunvisors
Front Door Trim (Passanger)
GTR Coin Slot Cover
Driver A Pillar Trim (Driver Side)
Electric Window Switch (Driver Side)
Floor Mats
Heater Box
Heater Core
Gyro behind Airbag
Airbag Sensor
Triple Gauges
Manual Surround
Head Unit
Fuel Filter Mount
triple guages sold but I have the centre console. $120 pickup or $150 delivered. pm me if interested.
cheers
update.. SOLD:
Fuel Tank & Pump
Engine & Gearbox
Exhaust
Airbox
BOV's & Return
PS Pump
A/C Setup
Wheels
Brakes
Brake Air Ducts
Hubs
Struts
Castor Rods
Sway Bars
Rear Driveshafts
Steering Column
Steering Rack
Strut Braces
Tailshaft
Rear Subframe
Diff
Atessa Pump & ECU
Relay/Fuse Box
Locks & Keys
Spare Tyre
Jack & Mount
Series 3 Xenons
Front Lip
Front Grille
Front Indicators
GTR Wing
Sideskirts
Side Mirrors
Fuel Cap Flap
Bar Skin (Rear)
Bonnet Lining
Guard Lining
Antenna
Seats
Seatbelt (Driver)
Steering Wheel
Instrument Cluster
Sunvisors
GTR Coin Slot Cover
Floor Mats
Heater Box
Heater Core
Gyro behind Airbag
Airbag Sensor
Triple Gauges
Manual Surround
Head Unit
Fuel Filter Mount
Front Bar Skin
  • 1 month later...
Probably not something you wan't to split, but the lock on the boot on its own?
Hi Borci88, everyone has a price but unfortunately full set of locks including the boot lock are long gone..
    • What could be causing my clutch problem besides a bad master or slave then? Both those parts are new
    • Just came across this, but in QLD I start leave again in 2 weeks, if it is still available I might drive up and check it out Unless, @MBS206 do you live near here????, if so I could hit you up with a finders fee https://www.gumtree.com.au/s-ad/hope-island/auto-body-parts/nc-mx5-factory-hard-top/1328976391
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
