Issue with my r32 rb20det skyline is that under acceleration it will accelerate between 2-3k RPM, bog down severely between 3-4k RPM and boost hard between 4-5k RPM and bog down again after that.
I have changed plugs/gapped, replaced and cleaned AFM, changed fuel pump/filter, confirmed correct timing.
Using consult cable I get a code 34 (Knock sensor - Not reading correct resistance) and no other codes.
I cannot find any vac leaks and everything is tight and connected..
I have a feeling because of code 34 it might be going into some type of limp mode but am unsure.
Also, when it bogs down the timing drops to 0-5 degrees..
Any feedback would be appreciated.
Edited by teteous
https://www.sau.com.au/forums/topic/427267-rb20det-lagbogging/
It's probably switching back to the knock fuel and ignition maps (the standard ECU has a proper set and a set it switches to when knock is detected). And the R32 ECU also then has the ability to pull even more timing out if it continues to have knock while on the knock map. This will make it as doughy as all get out. So, if your knock sensor is faulty (and let's face it, you can be pretty sure that it is!!) then it may be registering false knock and making the ECU spaz out.
Replace knock sensor with new one, or with ~500Ohm resistor, and see how you go.
Bought the car in not 100% running state, been slowly fixing it as listed above and this is the point I have gotten to.
So no idea on previous history. Is running a r34 turbo/gtr radiator, turbo back exhaust, constant power feed to fuel pump, air con/heater removed, everything else engine wise is standard.
Heading to Jaycar today to get the resistors, will putting the resistors directly into the ecu pin outs for both sensors work?
Edited by teteous
Only if you disconnect the wiring out to the sensors.
Ok, so i cut both 23/24, added the 470 ohm resistors to both and grounded the other end to a ground on the ECU.
It made a difference in the revs as soon as I did this as it was on a cold map (1700-2000rpm) and instantly dropped to hot map once the resistors were in.
But it still gives the knock sensor code 34 even after clearing, as soon as I start the car and the code re-appears.. Any ideas would be great.
when I got my skyline it wouldn't rev past 4500.the previous owner changed the usual crap that everybody changes when they don't know whats going on.ended up the fuel filter sock was full of brown crap.Old tank with a lot crap in it. I cleaned the fuel pump sock then I changed the fuel filter,problem solved,its worth a try.cheers
I don't know if 470 is close enough to the original sensor's impedence. Have a google around for what the best resistor value is. You may need to series or parallel another resistor on there to get closer.
Yea I was thinking that too so I read all the threads i could find and they either said 470, 500 (which isnt a actual resistor impedance) or 1M ohm.
I ran two of the 470's in parallel and it still has the code & hesitation (but reduced the idle weirdly), I guess I can try in series if that may make a difference. I guess next step would be to try another known working ECU..
I shall try that, I have another Bosch 040 laying around so I guess I can just swap that in and see if it makes a difference, it could be contributing to it :)
Edited by teteous
Not. Not 2x 470s. A 470 and a something else to get you closer to 500. Like a 47, or preferably something around 30 ohms.
And there is always the possibility that there is a damaged track inside the ECU to consider also. If that were the case, you could hook up whatever you liked and get the same result. I don't know if the knock sensor circuitry/tracks in a Nissan ECU have EVER been found to be faulty, but there's always a first time. Have you tried another ECU, just in case?
Thanks GTSBoy,
I have limited understanding of resistors, but wouldn't running x2 470's actually reduce the value by half (ie 470/2 = 235k ohm).. So really I should get x2 1M ohm resistors & run those in parallel to make exactly 500k ohm (but twice the wattage?).
Or alternatively run the 470 with say a 47 as mentioned in series?
Edited by teteous
Any two resistors in series simply add the resistance. So a 470 and a 47 = 517. That might be too high, so you could use a 30 instead of a 47 and get 500 exactly.
Two 470s in parallel gives you half the value of one of them (so you end up with 235 like you say), but this is useless to you. Yeah, you could get two 1M resistors in parallel, but I was assuming that given you already had the 470s it was worth starting there.
Jaycar's 510 ohm jobbies might do.
What would actually be smarter would be to get a variable resistor that works in your desired range and try adjusting it around the 500k mark and see if the fault code goes away. Could be tedious. But worth a try.
But one thing I think you have to be prepared for is that the problem may not be that the knock sensor resistance is actually out of range. There may be some other problem.
More swaptronics is also an option. Try to obtain another ECU and some knock sensors and see if swapping them out helps.
Thanks for all the info,
Got the 30 ohm & 1m ohm resistors (only $0.46/pack of 8 so why not..) and i'll test these out tonight. Hopefully being closer to 500 ohms will get it running again.
My mate is looking for a spare ecu, so if this fails i'll go down the swapping ecu's route.
how to you have the resistors connected u can use 1m ohm and connect both knock sensor wires together connect to one side of resistor then connect the other end of the resistor to a good ground. code should definitely go away after that.
Ill give it a go, I have pin 23/24 cut at the ECU loom which I soldered separately to each wire x1 470 & x1 30 ohm resistors in series. These both have the same ground of pin 50 (Ground control unit) - This is a known good ground as I have my SAFC connected to this ground also.
Edited by teteous
470k ohm resistor?
Just double checking. Also try 2 new resistors as i have seen them not work the first time
Ok ill try a couple more, I first tried 470's on each knock sensor, then tried 470 + 30 in series. After those failed I tried connecting both of the knock sensors wiring from the ecu together, attaching a 1M resistor and grounding that to the chassis but still have the same issue.
I've tried another ECU and same issue to rule that out.
  • 3 weeks later...
    • Have you checked the foam over the years? No deterioration to the foam from e85 mixing in oil? (assuming you're on E85)
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
