Hi Just trying to determine if my sensor is gone or something else is playing up.
ive noticed my water temp on the guage is very very low and seems to even go down after a 30min drive on fwy it went to a quater.
I warmed the car up for 15mins this morning with the heater on full and looked at powerfc and its sitting at 55degrees and no movement on the guage.
thermostat?sensor?bleed the system?
thoughts?
https://www.sau.com.au/forums/topic/427268-water-temp-real-low-alloy-rad/
thermostat, replace it
use a tridon one, they're fine. Just make sure the little bleed point is at the top or you'll have issues (as they're not marked like the Nissan ones)
don't use a low temp NISMO thermostat, pointless
Even further to this, last weekend whilst tuning my boost controller (so the engine should have been toasty warm) I coasted down a hill and the temperature gauge fell quite low. This finally convinced me that my thermostat (in my new Neo) was not right. Had been taking a long time to warm up in the cold weather we've had lately, and when looking at the actual coolant temp in Nistune it was lower than it should have been. And the last tank of juice went about 20% faster than the recent average.
Thermostat swapped out today. The one that was in there had damage most of the way around the edge. Not possible to tell if it warms up faster until tomorrow when it is fully cold again, but on the shakedown drive I noticed that the oil temp was back up to numbers that I haven;t seen since much hotter weather, so it would seem that it was the root cause of cold running.
    • Hi all. So I have my GTR on the lift and have been working on it a few days and yesterday I unpacked the frontpipe that was wrapped with heat wrap stuff, because part of it was breaking down and soaked in oil. Noticed that the pipe itself does not actually look like a Mines, despite it supposedly being a Mines. But I could not find any fronpipe online that looks exacly like his, and I don't think it is a custom one. My amateur measurement also showed the two pipes are about equal length, so maybe this is just an old version of the Mines pipe? Would appreciate insight on this by the enlightened folks. greetings from Germany
    • Yeah. If I plug the connector in and connect the vacuum lines, I assume worse case scenario is that it simply doesn't work? Yep PFC.
    • I would think that rather than attempting to perform an engine swap, with all the difficulties associated with doing so in a country where the raw materials required are harder to get hold of, I would just build the CA20 for boost, find an EFI manifold for it and either add a turbo or a supercharger. Or both. You replace one set of difficulties with a different set, but I know which would be more fun.
    • Well, a proper aftermarket ECU** SHOULD be set up to run the purge solenoid, same as the factory ECU would, so that the tank breather system continues to operate the way it is supposed to. I have no knowledge of whether the PFC (which is what I assume you mean when you say Apexi) has an output (and internal logic) to run the purge solenoid. If it does not, then given the product design intent for the PFC, which is to be a plug in replacement for the stock ECU, I would consider that a massive failing on Apexi's behalf and would be another reason to think that they were a half-arsed solution to the problem if programmable management on RBs. I would suggest that since Nistune came to market (which is a LOOOOONG time ago now) there has been no valid argument for choosing a PFC, especially if the PFC can't do things like this.   **ie, Haltach, Link, Motec, etc
    • Thanks for asking the question we were all thinking!
