Hi Just trying to determine if my sensor is gone or something else is playing up.
ive noticed my water temp on the guage is very very low and seems to even go down after a 30min drive on fwy it went to a quater.
I warmed the car up for 15mins this morning with the heater on full and looked at powerfc and its sitting at 55degrees and no movement on the guage.
thermostat?sensor?bleed the system?
thoughts?
https://www.sau.com.au/forums/topic/427268-water-temp-real-low-alloy-rad/
thermostat, replace it
use a tridon one, they're fine. Just make sure the little bleed point is at the top or you'll have issues (as they're not marked like the Nissan ones)
don't use a low temp NISMO thermostat, pointless
Even further to this, last weekend whilst tuning my boost controller (so the engine should have been toasty warm) I coasted down a hill and the temperature gauge fell quite low. This finally convinced me that my thermostat (in my new Neo) was not right. Had been taking a long time to warm up in the cold weather we've had lately, and when looking at the actual coolant temp in Nistune it was lower than it should have been. And the last tank of juice went about 20% faster than the recent average.
Thermostat swapped out today. The one that was in there had damage most of the way around the edge. Not possible to tell if it warms up faster until tomorrow when it is fully cold again, but on the shakedown drive I noticed that the oil temp was back up to numbers that I haven;t seen since much hotter weather, so it would seem that it was the root cause of cold running.
    • Oh, I forgot too, all the multimedia stuff captured and sold through things like people playing Pokemon Go. Pokemon Go specifically, can actually be traced all the way back to a CIA investment company too. So yep, they're watching everything. Not to mention the new stuff where they've worked out how to use WiFi signals to be able to map occupants inside of a building. That one would be something that I see being more used in public/government buildings, as you need to understand the signals when the room has no one in it first. It's not as easy as Hollywood would like you to think it is.
    • Followed ☺️ Assuming those are NEO rods, then at least 400kW all day.
    • Lets keep this going , Spotted this very stock V35 in Penrith and also saw a nice R32 FLY past me on Castlereagh rd , sounded really good.
    • Great work! Give it a clean up with some Emery paper, and I'd run a thread die over the threads too to clean them up. It will make reinstall much easier, and also life easier for the next time it needs to come out.
    • I'm not a fan of high humidity, it's one reason I don't mind being further inland out Ipswich, except the last 3 odd years, the drought broke, and it won't stop raining, which is making the humidity nearly unbearable when the rains are in during summer! For me, my body hates the cold, once the cold sets into my body, I'm totally screwed. I end up with severe muscle spasm in my back/shoulder muscles, and it feels like someone is trying to tear the muscles out. I have no issues with it getting stupid hot, so long as the humidity goes away. So the last 3 years as above, have been woeful! Ha ha. However, June 1st, and I'm only just converting from shorts and a tee, to long pants and a t shirt. And that's mainly as it's a bit wet and miserable and I wanted to work on a car.
