considering getting a hypergear highflow on my turbo as i want something i can upgrade later on but still run standard boost and not break the bank on a nig turbo.
just want to know if people have had experience with it. already been through the hypergear thread and called them about an hour ago.
just want to hear other peoples opinions before i got ahead and do this.
cheers :)
i couldnt find anybody who had done this before. wanted it from experience not what a shop says (i do trust hypergear). mayb i didnt look in the right spots.
cheers
if youve been through the hypergear thread then why are you posting this. go read it again.
then buy one.
cheers
Go back to the Hypergear thread and ask in there! Threads like this will get locked when the mods find it as the info is readily available on SAU.
Won't run well on stock ecu, needs an ecu and tune.
Not getting it tuned may result in a broken motor. Don't do it unless you get an ecu. Hypergear can supply an ecu for a reasonable price and a tune will cost about $600.
So in reality highflow 1k, ecu 1k, tune 600 = $2,600. If you dont plan to spend that much your adventure ends here until you can.
Then even if you do the above just remember thats not a complete package to get the most out of it, just the bare minimum to have the highflow WORK on your car with whatever else it has.
Good luck. End thread.
i bought the standard highflow.
fitted it on standard boost. it works but its not great, buy a second hand greddy emange and have it tuned. i did and i loved it man!
by not great do you mean better than stock but nothing crazy?
i need my turbo repaired anyway which is why im doing the high flow
alright sweet cheers will try find a good ecu. i got people who can hopefully help with a tune
as in it barely works. at all.
ignore the 2600 comment. can be had for a lot cheaper.
tune 700.
turbo 700 or less second hand.
emanage blue 200-300.
i got my turbo ecu and tune for 1400 bucks. that was ALOT of looking tho.
tune 700.
alrighty then thanks, so the product is actually e-manage blue? i guess i'll just be on google for a few days. second hand standard turbo did you mean?
Look around for a Apexi power FC. Don't bother with piggy back style ecus. Nothing beats a standalone unit.
You'll also need upgrade injectors (550cc min) upgrade fuel pump such as the Walbro or Bosch, and a bigger intercooler.
If you're going to exceed 220+ kw, then you'll need a z32 AFM.
After all these items are installed, car tuned you're all set for descent reliable power!
Have fun
tune 700.
Who is right and who is wrong here?
Me who is setting reasonable expectations if the person was to buy what was readily available and new?
Or you who is seemingly letting someone get their hopes up that they will score a steal on randomly available second hand goods?
Without knowing the condition of the car OR the parts currently fitted too it, anyone posting will be posting based on opinion only (E-mechanics)...
There is no real right or wrong in terms of the advice above BUT its better to give a worst case scenario based on the fact that it looks like OP is "saving" for it!
I would not use dodgy second hand parts on my car but it is a risk many take, and Plattsy has done so successfully!
Won't blow motor, ECU will just R&R and the car won't go anywhere.
Also stock ECU retards timing on knock.. will be fine.
Will just run like shit once it goes anywhere more than 0.5bar
My advice for parts, just keep your eye open on forums, eBay etc, there's always people stripping cars and you can get some really good parts from it if you're quick. Do you're research. Sometimes you'll get lucky. I picked up my high flow, injectors and z32 from one bloke, did a package deal and i got a great price overall. I got the PFC on eBay.
Half the fun is finding the parts!
nailed it.
f**k up scott. haha!
You assume.
Its possible to overrun the safety margin given by R&R, otherwise we would all just slap turbos on and push past R&R like in the fuel cut defender days. Realistically most of us now realise you don't need to HEAR knock for it to be present, and just because your car is hitting R&R doesn't mean it isn't knocking.
EAD Plattsy Faggsy.
    • I have two German Shepherds that like to bite things that are in places they shouldn't be. Plus the cars/batteries on chargers are inside a locked garage, inside that fully fenced and locked yard. If you can get the car out, you can have it, as I'll be having one hell of a laugh at your expense.
    • Looks like they changed the wording in the manual for the new model. I have a different model. Mine is CC1206. Not CC1206-XLI. Mine doesn't support lithium at all. I can't find the manual for my model online and they don't list the model on the Century website anymore either. In my manual it says what I quoted and that they recommend to not leave it on 🤷‍♂️ Sounds like you'd be fine with this one now.
    • Thanks for actually answering every single point! I noticed the date only after posting. And yes, looks like things have changed a little bit since then. FWIW, looks like Government Gazette No 253 has the current emissions test procedure. Sounds pretty reasonable altogether. One thing I learned from this is that it's possible to check whether a catalyst does any work by measuring the temperature. Catalyst outlet temp is at least 40°C higher than inlet temps if there is a reaction happening. I'd be curious to check this on mine but don't have a thermometer. Because purely going by smell it can't be doing much. Personally I'd be okay to pay for the test as long as it's within reason. My main concern would be to lose my rego because it definitely wouldn't pass the test in its current state. I'll see if I can do a bit more digging and see what's involved in doing this nowadays.   To be fair I don't think it's stopping many people from doing the modifications anyway. It just puts a barrier up to doing things right
    • Uhhh if anyone sees this - I bought a BRZ years ago, on my fulls soon so back on the market for the R34!
    • Research research research, and tackle the important things first, like the rust, because as a wise old hippie and some crazy horses once said "rust never sleeps" Nothing good comes easy and fast, and nothing that comes easy and fast is typically good
