I've got a muffler I want to get welded up. Looking for someone who wont charge through the roof.
Muffler has hangers from an R34 already on it. Looking for someone to cut off the stock one and weld this one onto the pipe. Nothing major, should take 20 minutes tops.
Closer to Eltham the better..
Should take 20 min tops? Lol are you a welder?
I would like to see someone that could jack a car up on a hoist, inspect what work needs to be done, if the entry pipe of the new muffler will even line up to the old one, remove the old rear section, measure what needs to be cut, cut the old exhaust, weld on the new one, adjust it to fit correctly, properly seal the welds, re fit and then get the car off the hoist, all in 20 minutes "tops"
Putting aside your judgement of time; I suggest the drive out to Hampton park and seeing Scotty for the job. He'll get it done good! And it will be better than you hoped
I don't mind paying a bit extra for an SAU member as long as they do a decent job.
The last one I got burnt a hole in the pipe and had to cut + weld a new section on it. They even charged me for the extra welding! How kind of them.
