left overy bits and pieces for sale from r32 builds.
Need $$ to finish my current drift build.
rb25det standard manifold (top & bottom)
$50
rb25det standard cross over pipe with blowoff valve
$20
rb25det aircon pump and bracket
$70
rb25det aircon assembly, including condensor, aircon radiator and piping
$50
rb25det flywheel needs machining
$25
r2000 diff out of r32 suit rebuild. shells in good condition, internals decided to let go in 3rd gear (not fun) $100
2.5L surge tank with machined holding plate and pump bracket. looks mint and is nice and tidy.
I never installed it i brought it off someone from SAU last year $150
rb25det standard injectors (high flowed)
$120
rb25det standard valve springs (used)
$50
rb25det standard fuel rail
$50
rb25det gearbox mount
$60
r32 gtst break discs F&R
(used condition)
$40
r32 gtst bonnet needs some bog and a respray from minor rear end love tap in traffic (oops)
$60
r32 black eclectric mirrors (L&R)
$40 ea or $60 for both
r32 gtst rear seats
$80
r32 centre surround w/ash tray
$50
r32 head lining w/sunroof
$60
r32 a,b and c piller interior covers
$60
r32 rear interior plastics
$30 ea $50 both
all the interior is in good condition
all prices are ono..
please msg me if your interested in photos
im located in Melbournes S.E suburbs, prefer local pick up
cheers James
Edited by R32-2840
https://www.sau.com.au/forums/topic/427288-fs-r32-rb25det-parts-vic-se/
  • 1 month later...
    • Holy hell! That is absolutely stunning! Great work!!!
