Hey guys. have a heap of stuff up for sale, thought I should post it up here.
all items pick up from brisbane. can deliver if really needed (prefer not) and can ship smaller items. or if you arrange it, can ship anything.
Power fc suit R33 GTST with hand controller - $900
power fc suit R32/R33 GTR, no hand controller - $600
power fc suit R34 GTR, with hand controller - $900
Z32 AFM, done 2 dyno pulls, no plugs - $200 each (3 of)
Greddy T78-33D, T4 flange plate, 4 bolt dump pipe. Rebuilt, new billet wheel. 17cm housing. $1300
Garrett 3788r, dual ball bearing, .89 rear, T4 flange plate, V band rear. 1000km old. $1200
Os Giken twin plate suit rebuild. 3 of. $350
Os Giken full rebuilt clutch, done 1000km. $750
OS Giken triple plate clutch, good condition. $700
RB25 gearbox. with shifter, fork, throwout. no noises or crunches $1200 (3 of) (also have tailshaft, mount etc)
R33 GTR gearbox. with shifter, fork, throwout. no noises or crunches $700 (also have mounts, tailshaft etc)
R33 GTR crankshaft. standard size, not spun, good condition. no marks. $400
Haltech platinum pro plug in. suit R32/33 GTR and GTST. near new 1000km. $1700
R33 GTR bonnet, perfect condition, silver, no marks/scratches etc. $550
text on 0427282562, barely make it on here. request pics via SMS if needed!
  • 4 weeks later...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
