Hi,
Just wondering if anyone has had brake switch as an error code come out of their V35 350GT-8 before.
The transmission service has been fully completed and computer reset but she is still not changing gears and we are getting brake switch error coming out of the tranny.
Have been corresponding with CVT NZ and Nuwan but we are all at a bit of a loss now.
Cheers
https://www.sau.com.au/forums/topic/427313-brake-switch/
Erggggggggghhhhhhhhhhhhhhh sorry to tell you champ, but once you have a problem with the GT8 trans that is it - you will fix one, develop a new error, fix the next, develop a new one etc etc etc ...... go read all the threads and nightmare stories .... most end up getting parted out ... didn't I warn you on here before you bought the car?
https://www.sau.com.au/forums/topic/427313-brake-switch/#findComment-6898250
Unfortunately I had already bought the car.
The general consensus from all who know a thing or two about them is our issue isn't the transmission. Appears we have a wiring issue with communication going to the transmission. So looks like the transmission isnt the bad guy this time.
https://www.sau.com.au/forums/topic/427313-brake-switch/#findComment-6898414
Check that the ecu is getting it's brake signal to the engine ecu, pin 101 I think. That would throw an engine light though. I don't think there is a direct brake signal to the gearbox but I haven't played with the cvt's at all yet.
If it is in the box you will need to get it on a consult 3 unit for diagnosis. What unit did you use to read the error? Do you have the code number?
https://www.sau.com.au/forums/topic/427313-brake-switch/#findComment-6899111
The mechanic used consult 2, I have just asked if we can get a consult 3 to hook up to it.
In the G35 manual it appears that the brake switch is apart of the vehicle stability system and the switch most would classify as the brake switch is in fact called the vehicle stop light switch. So we are seeing what we can find in relation to the wiring for this ASCD Brake Switch to see if it could be this.
Hopefully the consult 3 gives us some more information.
https://www.sau.com.au/forums/topic/427313-brake-switch/#findComment-6899545
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
