1999 Nissan S15 Jdm Spec-R $15K Neg. [Vic]
Nissan Silvia S15 99' JDM Spec-R
Color is Pewter
100,XXXkms
SR20DET 6 Speed manual
Exedy Heavy duty clutch
Locked diff
Pod filter
Braided turbo lines
Cusco Coilovers
Stainless steel exhaust turbo back
Genuine Advan RG-D 18" wheels
Kenwood headunit with mp3, Aux
Has an amp but no subby
Aftermarket taillights
Turbo Timer
Pillar mount boost gauge
Turbosmart boost controller
Looking to sell my car, not much to really fault about it only negative things about it is the front bar and bonnet will need some paint.
Car comes with 11 months rego (May 2014)
I am slightly negotiable on price, but dont offer me ridiculous prices as i will just say no, i am no desperate to sell it so If you can get an S15 cheaper from your mate or cousin by all means go get it lol.
No test pilots or tyre kickers unless i believe you are interested on buying it.
Located in St Albans, available for viewing most days of the week.
post-59775-0-45606200-1371707200_thumb.jpgpost-59775-0-23164500-1371707208_thumb.jpgpost-59775-0-28700300-1371707209_thumb.jpgpost-59775-0-55191800-1371707210_thumb.jpgpost-59775-0-69417100-1371707211_thumb.jpgpost-59775-0-82885900-1371707212_thumb.jpgpost-59775-0-85256800-1371707213_thumb.jpgpost-59775-0-03775600-1371707215_thumb.jpg
 Share
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
