Hey everyone!
Its been way to long since a good Newcastle organised cruise, (mainly because all 5 of us have been busy as with other things). so this one has to be an awesome come back!
so the plan is, we will be doing the north section of putty road (as its the only part worth doing), instead of the boring hwy there and back were going to be going on some fun familiar roads to get there, basically trying to roll 3 cruises into 1 without going through a lot of petrol.
The route, makes for a 3 hour trip of fun!!!
SYDNEY PEOPLE; if you want to meet up along the way just say where and write you on the attendance list so you don't get forgotten about, I recommend meeting at wollombi as the first half of putty rd is very boring and youll still get a lot of fun driving time. If not the halfway point on putty road will still get you a lot of driving and shit talking
an epic cruise for Sydney people will be old pac to peaks ridge to wollombi and continuing on with
Meet at 9am, to leave at 930, the drive takes 3 hours to get to the end point which is where we will be having lunch at singleton pub that weve been to before.
Meet point, United petrol station 971 Freemans Drive
lots of parking space, looks to be a very generous driveway.
We will be stopping if required to meet up with people from Sydney at wollombi and ofcoarse the putty half way point. the cruise is only 3 hours with 1 break so if you cant control your bladder youll have to catch up :P
Parking is limited in wollombi so id prefer not to stop, but if need be we will pull in at the pub, we just open the gate and drive into the meadow as does on previous cruises. hopefully we don't need to as id feel bad having 30 cars pull in just to take a piss and then leave without buying anything. PEOPLE WANTING TO JOIN HERE, BE HERE BY 10:10 SO IF WE SEE YOU, YOU CAN JUST JUMP ON THE END OF THE GROUP SO WE DONT NEED TO STOP.
This is the half way point on putty road if anyone doesn't know it. im sure well stay here for a good 30-1 hour talking crap. PEOPLE WANTING TO JOIN HERE, WE WILL ARRIVE AT AROUND 1130
From putty, we will head to singleton for lunch at the albion pub! we will arrive at 1230 for all the snittys they have.
After lunch i'm guessing everyone will be splitting up, Sydney people down putty, central coast people down through Cessnock and Newcastle people through Branxton (or a little detour that I have in mind ;).
IT WILL BE A GREAT DAY!!! IT WILL BE A BAD DAY IF PEOPLE WITH THE WRONG ATTITUDE COME WITH EXCESSIVE REVING IN PUBLIC AREAS, BURNOUTS, DANGEROUS DRIVING.
were going to have fun, on some of the best roads in the state, we don't need idiots wrecking it.
Now THIS is how you do a cruise thread ;) nice word Jarrad.... Martin take notes :P
Remember guys this is just a meet'n'greet at this stage :yes: like minded guys driving the same road hehe
Okay notes taken
I think J-Rad should do all the cruise threads from now on
And in like Flynn for this as well
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
