Spewing I am guna miss this as my car still isnt ready :verymad:
Jump in with someone else? Get too meet some good people anyway?
On that note, ill try get my car limping on Saturday for the run, however its got a few things i havent fixed so there will be no spirited driving from me, i am volunteering to go ahead in sections and pull up and do photos and video for you guys, i will need someone to lend me a radio if we do so i can get you to space out a bit to make it easier! Everyone loves a good rolling shot!
Ill see how things pan out. Id love to go, but i also have to come up from wollongong, so would rather be in my own car.
Yep fair call mate! We run a few events up here as the boys love cruising :yes:
ive got a 2way you can borrow.
but im doing the half putty meet up.
Might sort it with you on the day! Will have a phone but of course as we wil all be abiding by the road rules i wont be using it :ph34r:
WTF is it with you and your car
Makes great numbers then breaks
Gets fixed and makes better numbers and is now broken again?
I think I've got my 7D car mount sorted, so some highway rolling videos should come out awesome!
What channel are we using on the 2way? It may have been mentioned earlier, but CBF going back.
sounds good mat. even if you leave earlier thrn us at stops amd pull over and well zoom past. stay spaced until we see you :)
Yep that is the plan!
It hasnt broken, it just hasnt been fixed since the last time i damaged it! Its suspension and brakes, nothing to do with the rest of the car ya clown :P
its karma for giving me shit :D
That is never going to change!
Build it, tune it, race it, break it, fix it, repeat it.
I like this!
Nice one mate! Should be good!
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
