Hi Everyone
Im Looking for a cannon for my r33 skyline ( non turbo rb25de not sure if its different ) coupe but i was hoping
someone had one that bolts straight up as i dont want to weld it on
Thank You
hey mate, i have an r33 3" catback with mid muffler and rear cannon. the mid muffler has a dent in it, but no leaks, full stainless system.
i'm in SE burbs Melb. pm me if interested :)
iv got a 3" on mine now i just want an cannon that bolts straight up to it bro i dont want to weld andthing it just makes life easier when you can just
bolt it straight up
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
