Due to un-forseen circumstances my gtir in winter green is going up for sale..
This is the rarest colour of all the gtir's and you are highly unlikely to see another in this condition spec or colour.
2nd owner in oz since 2004 never ever modded thrashed or abused extremely well looked and possibly the best you will ever see....
Basic's...
WA rego til Aug 2013
94k
Full service history including recent full service.
Factory stereo system with Nissan ddpr rear speakers. (Rare)
Nismo front strut brace. (Rare)
Nismo rear strut brace. (Rare)
Nissan front bash plate
Nissan head lamp protectors.
Factory heated mirrors (Rare).
Interior is like new and still has the original flare head unit and floor mats.
Engine makes no odd noises has no oil leaks etc
Gear box is perfect and has recently (in the last 20k ish) had a new clutch
Bodywork has the odd car park dent, stone chip and slight fading on bonnet vent and roof (but no laquer peel) polish should cure this...
Anyway I will let the picture's do the talking its now on WA plates not NSW.
Any questions pm me I am looking at offers in the region of $13k
This is a very rare opportunity to get one of the best gtir's out there.
T2eC16NHJHgE9n0yEjMRBRBN670LbQ60_3_zps51
T2eC16JHJHYE9nzpcwE8BRBN6wlP860_3_zps662
T2eC16FHJHIE9nysd-NMBRBN6mfmmQ60_3_zpsf3
KGrHqVHJEFDzyd5HPbBRBN7KyZhg60_3_zps278d
KGrHqFHJFYFD1bLiJBRBN65tDU60_3_zps61e936
KGrHqFHJEoFD0PVlgOrBRBN6qY4hw60_3_zpsa6b
Wow.
That GTiR looks great. good price for the condition and rare colour..
Remember a worked gold one of these in Canberra - Quick as !
GLWS. Shouldn't last long.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
