Hi Guys,
I have a problem at idle with my GTR, cylinder number 5 is not running when idleing or not under load, When the engine get some load, it kicks back in and runs fine with plenty of power. I have replaced all 6 spark plugs, i have swapped over the coil packs with others and its not a coil pack issue. However when i Unplug the plug to the 5th coilpack, the revs don't change/drop. So I'm guessing it has something to do with the plug/wiring?
Anyone got any advice before i start replacing everything?
I recently replaced the whole engine and got it tuned. This started happening a day after i got it tuned. Took it back to the mechanics who installed the motor and they couldnt find the problem...
Any help would be greatly appreciated!
Swap your number 1 and 5 coil packs and see if the problem moves. If it does you know where your problem is.
Next, run the engine with the number 5 coil pack out of the head, and with a spare plug in it, sitting on top of the motor and watch for spark. If there is no spark, then its wiring or ignitor.
If there is spark you need to eliminate fuel. Swap the number 5 and 1 injectors and see if the problem moves. If it does, then injector. If not, then potentially wiring or ECU issue.
Borrow a stock /replacement ECU from someone and see how it goes. Have your tuned map uploaded if need be.
  • Like 1
Sounds like it could be a blown intake gasket on that cylinder. Get some brake cleaner or wd40 etc and while the car is idling spray around cylinder 5 inlet, throttle gasket and injector oring etc. see if the idle changes
I have tried swapping my number 1 and number 5 coil packs and it made no change.
I will try the rest when I get a chance this week. Thanks for the info, will let you know how I go!!
Sorry forgot to mention, also when its a cold start, the revs drop quite a bit and struggles to stay on (turns off most of the time), i need to keep my foot on the accelerator for about 15-20 seconds before it stays on..
So i tried spraying some throttle body cleaner on the injectors earlier, the revs did not change on injectors 1, 2 and 3. however the revs went higher by 100-200 rpm.. when sprayed on injectors 4, 5 and 6.... when i sprayed it on all 3 at once, the revs jumped upto 500 rpm.
Does this mean the intake gasket is leaking towards the back? Could this be the issue or is this an entirely new issue?
Yes sounds like the inlet gasket is blown. Its pretty common to happen as the gasket gets old. I normally replace the inlet and throttle gaskets with a set of metal nitto gaskets. Also check all the hoses under the plenum as they may need replacing while the plenum is out
Is that the gasket from runners to head? Shouldn't be hard. I think the rb25 plenum to runners is probably the ugliest job to do. I did it without a guide but there should be something readily available. Google change rb26 plenum gasket or intake gasket.
Its a veryfun job to do on RB26's. willtake atkeast 3hours to get off, then cleaning of old gaskets and replacing hoses etc. then atleast 3hours to get back on.
DO NOT CLEAN IN AND AROUND THE THROTTLE BODY BUTTERFLIES!!!
    • Come to Eastwood, you'll get plenty of that 馃ぃ
    • Oof, I will forevermore have those shredded gears in mind whenever someone talks about showing mechanical sympathy towards their car. Thanks for the photos, fascinating stuff!
    • Curious to see how the SpeedTek stuff holds up
    • The holdups last year were drivetrain related. I had the car out right after getting the bearing issue resolved. Third launch and the car didn't move after releasing the clutch. It had sheared all the engagement teeth off the 1st gear.    Thankfully no other damage was done. I set an aftermarket gear beside an OEM gear and found that the engagement teeth on the OEM gear were much larger and better supported. Looking through my bin of spare transmission gears I found that there are two types of tooth on the OEM first gears - the larger tooth and the smaller tooth. It looks like most aftermarket gearset manufacturers base their design on the smaller tooth. OEM large tooth left - Speedtek, OS Giken, etc or OEM small tooth right Decided to give that larger engagement tooth a try. Pressed the ring off an OEM gear and sent it to a transmission manufacturer here in the States. They did their "faceplating" operation with my synchro ring on the Speedtek gear.   I reassembled it, took it back to the track and promptly destroyed the gear itself.  I'll rebuild this and use it as a spare - thankfully just first gear and the countershaft are damaged beyond repair. Definitely disheartening but my welded on engagement tooth ring held up!  Moved to Speedtek's dog engagement design as the gears appear to be much stronger. So far they have taken much more abuse at the track. Also scored a Stillway lockout from the Netherands for super cheap. It's for some other RB transmission so it took a bit of fabrication to fit but honestly a very easy job. I also had to heavily modify the gates as they were very different.   Then for some reason at the last test and tune a silicon coupler below the throttle blew off and took out the radiator and fan. Thankfully it was in the burnout box and not down track. This car is really beating me up - I still haven't made a pass in it. Ran it through the gears many times on the street but it keeps biting me at the track.  Currently in the process of replacing the radiator and remaking the throttle pipe to remove the coupler and use a cast 90 and a vband. I WILL get this thing down the track...
    • Covers most of the above points really. There's a few exceptions but most just see driving as an irritating but necessary task they must complete if they want to get anywhere on time. Also see it as a good time to show their awesome multi-tasking abilities on their mobile and/or doing their makeup.
