Hi Guys,
I have a problem at idle with my GTR, cylinder number 5 is not running when idleing or not under load, When the engine get some load, it kicks back in and runs fine with plenty of power. I have replaced all 6 spark plugs, i have swapped over the coil packs with others and its not a coil pack issue. However when i Unplug the plug to the 5th coilpack, the revs don't change/drop. So I'm guessing it has something to do with the plug/wiring?
Anyone got any advice before i start replacing everything?
I recently replaced the whole engine and got it tuned. This started happening a day after i got it tuned. Took it back to the mechanics who installed the motor and they couldnt find the problem...
Any help would be greatly appreciated!
Swap your number 1 and 5 coil packs and see if the problem moves. If it does you know where your problem is.
Next, run the engine with the number 5 coil pack out of the head, and with a spare plug in it, sitting on top of the motor and watch for spark. If there is no spark, then its wiring or ignitor.
If there is spark you need to eliminate fuel. Swap the number 5 and 1 injectors and see if the problem moves. If it does, then injector. If not, then potentially wiring or ECU issue.
Borrow a stock /replacement ECU from someone and see how it goes. Have your tuned map uploaded if need be.
  • Like 1
Sounds like it could be a blown intake gasket on that cylinder. Get some brake cleaner or wd40 etc and while the car is idling spray around cylinder 5 inlet, throttle gasket and injector oring etc. see if the idle changes
I have tried swapping my number 1 and number 5 coil packs and it made no change.
I will try the rest when I get a chance this week. Thanks for the info, will let you know how I go!!
Sorry forgot to mention, also when its a cold start, the revs drop quite a bit and struggles to stay on (turns off most of the time), i need to keep my foot on the accelerator for about 15-20 seconds before it stays on..
So i tried spraying some throttle body cleaner on the injectors earlier, the revs did not change on injectors 1, 2 and 3. however the revs went higher by 100-200 rpm.. when sprayed on injectors 4, 5 and 6.... when i sprayed it on all 3 at once, the revs jumped upto 500 rpm.
Does this mean the intake gasket is leaking towards the back? Could this be the issue or is this an entirely new issue?
Yes sounds like the inlet gasket is blown. Its pretty common to happen as the gasket gets old. I normally replace the inlet and throttle gaskets with a set of metal nitto gaskets. Also check all the hoses under the plenum as they may need replacing while the plenum is out
Is that the gasket from runners to head? Shouldn't be hard. I think the rb25 plenum to runners is probably the ugliest job to do. I did it without a guide but there should be something readily available. Google change rb26 plenum gasket or intake gasket.
Its a veryfun job to do on RB26's. willtake atkeast 3hours to get off, then cleaning of old gaskets and replacing hoses etc. then atleast 3hours to get back on.
DO NOT CLEAN IN AND AROUND THE THROTTLE BODY BUTTERFLIES!!!
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
