Hi Guys,
I have a problem at idle with my GTR, cylinder number 5 is not running when idleing or not under load, When the engine get some load, it kicks back in and runs fine with plenty of power. I have replaced all 6 spark plugs, i have swapped over the coil packs with others and its not a coil pack issue. However when i Unplug the plug to the 5th coilpack, the revs don't change/drop. So I'm guessing it has something to do with the plug/wiring?
Anyone got any advice before i start replacing everything?
I recently replaced the whole engine and got it tuned. This started happening a day after i got it tuned. Took it back to the mechanics who installed the motor and they couldnt find the problem...
Any help would be greatly appreciated!
Swap your number 1 and 5 coil packs and see if the problem moves. If it does you know where your problem is.
Next, run the engine with the number 5 coil pack out of the head, and with a spare plug in it, sitting on top of the motor and watch for spark. If there is no spark, then its wiring or ignitor.
If there is spark you need to eliminate fuel. Swap the number 5 and 1 injectors and see if the problem moves. If it does, then injector. If not, then potentially wiring or ECU issue.
Borrow a stock /replacement ECU from someone and see how it goes. Have your tuned map uploaded if need be.
  • Like 1
Sounds like it could be a blown intake gasket on that cylinder. Get some brake cleaner or wd40 etc and while the car is idling spray around cylinder 5 inlet, throttle gasket and injector oring etc. see if the idle changes
I have tried swapping my number 1 and number 5 coil packs and it made no change.
I will try the rest when I get a chance this week. Thanks for the info, will let you know how I go!!
Sorry forgot to mention, also when its a cold start, the revs drop quite a bit and struggles to stay on (turns off most of the time), i need to keep my foot on the accelerator for about 15-20 seconds before it stays on..
So i tried spraying some throttle body cleaner on the injectors earlier, the revs did not change on injectors 1, 2 and 3. however the revs went higher by 100-200 rpm.. when sprayed on injectors 4, 5 and 6.... when i sprayed it on all 3 at once, the revs jumped upto 500 rpm.
Does this mean the intake gasket is leaking towards the back? Could this be the issue or is this an entirely new issue?
Yes sounds like the inlet gasket is blown. Its pretty common to happen as the gasket gets old. I normally replace the inlet and throttle gaskets with a set of metal nitto gaskets. Also check all the hoses under the plenum as they may need replacing while the plenum is out
Is that the gasket from runners to head? Shouldn't be hard. I think the rb25 plenum to runners is probably the ugliest job to do. I did it without a guide but there should be something readily available. Google change rb26 plenum gasket or intake gasket.
Its a veryfun job to do on RB26's. willtake atkeast 3hours to get off, then cleaning of old gaskets and replacing hoses etc. then atleast 3hours to get back on.
DO NOT CLEAN IN AND AROUND THE THROTTLE BODY BUTTERFLIES!!!
    • Hello! Long time lurker, been using the forums to address concerns and questions from afar for a while but I've struggled to find some answers so I guess its about time I made an account and formally asked some more knowledgeable people, since finding local skyline owners is hard (and shops that are knowledgeable or trustworthy to work on 'rare' cars are non existent out where im at, as skylines are quite uncommon to find in the wild around here). So the main 3 questions I have, 1: Steering rack has blown seals, well.. they kind of hold but they are not sealed properly anymore and as my R33 is my DD, i cant exactly rip the rack out and send it off or attempt to fix myself. As most refurb ones are around $1,100 or more shipped, and I have other things I need to work on around the car, I was seeking clarification on whether an S15 rack will more or less bolt right in, and whether a common mechanic could do any other required work to get it to fit. I ask, as I've found a supplier than can sell a manufactured as oem one for around 400, if not I'll likely order a used one from Jacks JDM, and take a risk on the seals there. The second question i have is that im replacing the front wiper cowl and have planned to buy 4 new clips and a new center clip but wasnt sure if there were any other clips that would also need to get replaced while I was at it. Given im sure any that are there now will simply break when I remove the old cowl... Last thing would be a fairly straight forward question, i think. If I manage (strong if, finding one has proven to be a pain) to find a R33 GTR spoiler/wing will it require much modification to bolt to a S2 R33 GTST? I've read the bolt patterns dont match but otherwise would bolt in, only options I have found with much luck is China stuff on ebay and carbonetics, which has a nice $650 shipping fee... so if anyone has any pointers where a US chap could locate one that would be great Random side question as well, the mirrors as I understand are mirror glass, and as im planning to polish my windows from water spots and surface scratches, i was hopeful cerium oxide would be fine for them too, as my research points to, but clarification is always nice. Any pointers would be appreciated, and while I have scoured the internet for answers if I missed a prior post somewhere that may answer these directly please point me towards it, as i must have simply missed it. I have seen a post here or there that has mentioned it, but I usually get 50-50 answers, or half answers... I dont have a lot of fab experience or mechanic experience, outside of hydraulic and pneumatic stuff I did in the military and with how hard it is to source stuff in the US, id rather not wing it and hemmoraghe money lol. Thanks guys! Sorry for the monumental first post haha
    • Yep, there's a very minor drift left that happens a few seconds after letting go of the steering wheel, but not enough to bother me. Enjoying the car still!
    • Got you mate. Check your email!
    • I see you've never had to push start your own car... You could save some weight right now...
