Anything I should know about doing this? Take off the wipers and then under the screws? The screws are a funny profile on the head, sorta square shaped. Are they screws or a type of automotive fixing? Just unscrew them? Just don't want to get half way through and find it's harder than it looks......
Thanks guys.
It's very easy.
Your on the right track. Remove the wiper arms first.
With the clips they're automotive fixings. Be careful when removing.
If I remember correctly it's a half turn and lift.
Remove the rubber strip at the base. There will be "T" pieces holding it on. Just stretch one way and lift off.
It's likely going to be gungy under there . Mine was dried up mould but cleaned up easy and looks great.
Ps. If you happen to loose or break one of the fixings O'briens will have some :)
Mine were easy and never looked like breaking.
When Obriens came around to put my new OEM windscreen in he was surprised that I hadn't broken or lossed any.
That's why I mentioned being careful
Any dramas leaving the plastic panel off for a while whilst exposed the rain? I note that there is a large opening under the grilled section and I'm unsure where this goes to. I presume it drains as normally water would go through the grill and into it?
After. Some surface rust which I'm wondering how to deal with. I guess to do it properly I'll have to mask, sand, and use some sort of rust inhibiting primer (which hopefully will roughly match the grey). Bottom winscreen wiper nuts are corroded so I'll loosen them and try and make sure they no not sieze and the bolt thread is still OK.
So, under that plastic panel lurks all sorts of mud and dirst and grime which idealy would get cleaned out every couple of years. Another area I've noted that traps a lot of grime is behind the tail lights. I'll get onto this fairly soon as it looks filthy in there.
I've actually covered the car with a cover whilst the plastic panel is off as I think water will get into the engine bay without it.
  • Like 1
Oh yeah, the rubber strip does need to come out and I found the only way to do this was to use a flat screw driver blade and carefully pry out the fixings. By the look of them they just press back in so I think this is actually the way to remove them rather than just my hamfisted ways. They are actualy integral to the strip so you can't actually get to them as they are housed within it. Anyhow hope this is helpful to other in the future.
So.......the Autobarn guy didn't really inspire me with a lot of confidence with his advice so I thought I'd come here. The question I have is how I deal with the rust. Most of it is surface but there is one small spot (say 5mm diameter) which looks a little more serious. I'm thinking I sand back the surface rust, dig out the 5mm spot, and then spray with.....?
Clearly the black cover will hide any paint I put on there but I'd prefer to keep it looking as factory as possible so can anyone recommend a product that will match the underbonet colour for a silver GTR and that will be appropriate for addressing the rust as described. I think there are paint products that actually turn rust into something benign, but are they only available in black?
Thanks.
Thanks.
fill and paint over? also, no idea what product this is but just an idea, even if this product is black then you can just paint over it again...right?
Kill rust is a clear solution you could try
http://www.wattyl.com.au/en/find-the-right-product/exterior/Metal/Prepare/WattylKillrustRustEeter.html?preview=true
Supercheap sells white kill rust epoxy enamel
Edited by BstewyR33
Went the easy / smart solution and took it to Micolour to get it sorted properly. Had some other minor blenishes attended to whilst I was there and also got the front guards spaced out for tyre clearance without losing my guard liners.
Looks too good to put the gutter back on!
I get it back today and will get her cut and polished next week after the rear diff rebuild.....Look out bank account.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
