Is An 'ecutalk' Usb Consult Cable The Correct Interface For Checking Ecu Codes/faults/info?
Unsure if there is anything better out there and if this is a good buy for inspecting/general maintenance and does it work with R32/33/34 skylines?
http://www.ebay.com.au/itm/ECUTalk-USB-Nissan-Consult-Cable-Skyline-Silvia-300ZX-Pulsar-200SX-Micra-NX-/321144840234?pt=AU_Car_Parts_Accessories&hash=item4ac5b9602a
Also if you can, I'll be inspecting a skyline soon. Wondering if you could give me any skyline specific tips, like what to look for specifically when I view the ECU information.
Should I run through all the cylinders individually (turn off ignition one by one) to check for misfires etc?
Thanks, any help would be greatly appreciated.
Edited by threez
Yes an ecutalk will work with r33 and r34 skylines, but from memory it won't work with the r32 unless it has had a consult port installed.
As for plugging in the laptop when buying a car, it's not really worth the trouble. You will be able to tell if there is a problem by driving it, and the consult will only really tell you if there is an electrical fault. You still need to look for any physical damage/wear and tear
Turning off a cylinder won't check for a misfire, it will just pin point which cylinder has a proven.
Plugging in would give you stored fault codes.
Cheers. Haha yeah was talking only about the electrical system, obviously the mechanics of the car is different.
Just curious is this is the best way to do so or if there is something else which is better/has better software etc.
The software included with ECUTALK would also tell me things like A/F ratio, sensor information etc, correct?
It would be handy to know the tune it's running etc, if it displays all that info. I guess I'll check the website.
Yeah that's what I meant lol
Are there any particular fault codes I should ignore or look out for?
As the o2 sensor is a narrow band, it can't really show the afr, only when it is at 14.7 .
I think at the end of the day plugging in is pointless if the car is running well.
Okay no problem. I guess I will save myself 90 bucks then :)
  • 6 months later...
hey guys wanting to buy a Nissan consult cable to read/diagnose sensors/ faults/ codes (R34GTT) via laptop, is this cable the right one:
http://www.ebay.com/itm/Diagnostic-Interface-for-14pin-RS232-Cable-Consult-Port-for-Nissan-vehicles-Seat-/330900689074?pt=Motors_Automotive_Tools&hash=item4d0b37d0b2&vxp=mtr
thanks
Edited by rondofj
I bought something similar from ebay, and had problems with it, so I went and bought a PLMS one, have not had one issue with it.
http://www.plmsdevelopments.com/consult_if.shtml
yes doing the 'compression check' check via switching off cylinders and the the program monitoring the cranking differences in voltage can give an idea if there is anything serious going on. I did with mine before purchase (indicated less than 2% variance between the cylinders overall) and think it was a worthwhile check.
I think you need the full nistune license program for this. Also don't be turning up to inspect a car as your first time trying to connect to a skyline ecu via a consult cable. most people have a lot of comport and troubleshooting issues to get the connection working right the first time. (took me 3 hours of troubleshooting before I got it to work).
    • Yeah the latest style kit has been trouble free, I've done a fair few klm on it including pushing a bit on low fuel and it hasn't been surging (that's not an endorsement for race use, I haven't tried that low, or that hard cornering!). For street use it has been a good thing, handles the high current OK, only real issue is it is not cheap
    • So, how do you feel about the Frenchys surge tank setup @Duncan? Have you had a chance to try it out more? The sketchy wiring in my fuel pump setup has decided to melt and die and I'm looking for a solid replacement now. My fuel hat is toast so the Frenchys kits providing it all look promising.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 馃槀  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
