Is An 'ecutalk' Usb Consult Cable The Correct Interface For Checking Ecu Codes/faults/info?
Unsure if there is anything better out there and if this is a good buy for inspecting/general maintenance and does it work with R32/33/34 skylines?
http://www.ebay.com.au/itm/ECUTalk-USB-Nissan-Consult-Cable-Skyline-Silvia-300ZX-Pulsar-200SX-Micra-NX-/321144840234?pt=AU_Car_Parts_Accessories&hash=item4ac5b9602a
Also if you can, I'll be inspecting a skyline soon. Wondering if you could give me any skyline specific tips, like what to look for specifically when I view the ECU information.
Should I run through all the cylinders individually (turn off ignition one by one) to check for misfires etc?
Thanks, any help would be greatly appreciated.
Edited by threez
Yes an ecutalk will work with r33 and r34 skylines, but from memory it won't work with the r32 unless it has had a consult port installed.
As for plugging in the laptop when buying a car, it's not really worth the trouble. You will be able to tell if there is a problem by driving it, and the consult will only really tell you if there is an electrical fault. You still need to look for any physical damage/wear and tear
Turning off a cylinder won't check for a misfire, it will just pin point which cylinder has a proven.
Plugging in would give you stored fault codes.
Cheers. Haha yeah was talking only about the electrical system, obviously the mechanics of the car is different.
Just curious is this is the best way to do so or if there is something else which is better/has better software etc.
The software included with ECUTALK would also tell me things like A/F ratio, sensor information etc, correct?
It would be handy to know the tune it's running etc, if it displays all that info. I guess I'll check the website.
Yeah that's what I meant lol
Are there any particular fault codes I should ignore or look out for?
As the o2 sensor is a narrow band, it can't really show the afr, only when it is at 14.7 .
I think at the end of the day plugging in is pointless if the car is running well.
Okay no problem. I guess I will save myself 90 bucks then :)
  • 6 months later...
hey guys wanting to buy a Nissan consult cable to read/diagnose sensors/ faults/ codes (R34GTT) via laptop, is this cable the right one:
http://www.ebay.com/itm/Diagnostic-Interface-for-14pin-RS232-Cable-Consult-Port-for-Nissan-vehicles-Seat-/330900689074?pt=Motors_Automotive_Tools&hash=item4d0b37d0b2&vxp=mtr
thanks
Edited by rondofj
I bought something similar from ebay, and had problems with it, so I went and bought a PLMS one, have not had one issue with it.
http://www.plmsdevelopments.com/consult_if.shtml
yes doing the 'compression check' check via switching off cylinders and the the program monitoring the cranking differences in voltage can give an idea if there is anything serious going on. I did with mine before purchase (indicated less than 2% variance between the cylinders overall) and think it was a worthwhile check.
I think you need the full nistune license program for this. Also don't be turning up to inspect a car as your first time trying to connect to a skyline ecu via a consult cable. most people have a lot of comport and troubleshooting issues to get the connection working right the first time. (took me 3 hours of troubleshooting before I got it to work).
    • On the compressor side it looks like the best, if your head setup will support doing 100-110lb/min at 30psi-ish boost.   The G45-1350 compressor looks ideally better if you need closer to 40psi for it, given both the G40 1150 and G42 1200 look like they'll be around the 100lb/min mark at 35psi and dropping from there.   Bear in mind the turbine sides are all different between those three turbos, so that COULD be an influencing factor for how they all perform in the real world as well.   Not sure if you've made a conscious decision to only look at Garrett or not, but at least on paper the XRE7169S matches or beats those other three at everything from 30psi up and just going from wheel size alone likely to be at least as responsive as the G40 1150 and seem to behave closer to G42s in terms of turbine flow.
    • @Lithium  looking for a turbo for my Rb30. Want to make sure I understand this correctly.   If I want to stay 40psi or under my best choice of these 3 is actually the smaller G40-1150 ?
    • Massive ups for MTHire also. Could not have done the subframe bushings job without hiring the tool from them. Process was super easy and cost me around 25% of the cost of the tool. If you need a tool to do a one-time job, check them out. (Paid for the rental myself, no sponsorship here.)
    • I'd suggest calling Unigroup, they have a lot of experience with these, access to reliable fabricators etc. Of course it will cost but at least you can trust what they tell you
