Is An 'ecutalk' Usb Consult Cable The Correct Interface For Checking Ecu Codes/faults/info?
Unsure if there is anything better out there and if this is a good buy for inspecting/general maintenance and does it work with R32/33/34 skylines?
http://www.ebay.com.au/itm/ECUTalk-USB-Nissan-Consult-Cable-Skyline-Silvia-300ZX-Pulsar-200SX-Micra-NX-/321144840234?pt=AU_Car_Parts_Accessories&hash=item4ac5b9602a
Also if you can, I'll be inspecting a skyline soon. Wondering if you could give me any skyline specific tips, like what to look for specifically when I view the ECU information.
Should I run through all the cylinders individually (turn off ignition one by one) to check for misfires etc?
Thanks, any help would be greatly appreciated.
Edited by threez
Yes an ecutalk will work with r33 and r34 skylines, but from memory it won't work with the r32 unless it has had a consult port installed.
As for plugging in the laptop when buying a car, it's not really worth the trouble. You will be able to tell if there is a problem by driving it, and the consult will only really tell you if there is an electrical fault. You still need to look for any physical damage/wear and tear
Turning off a cylinder won't check for a misfire, it will just pin point which cylinder has a proven.
Plugging in would give you stored fault codes.
Cheers. Haha yeah was talking only about the electrical system, obviously the mechanics of the car is different.
Just curious is this is the best way to do so or if there is something else which is better/has better software etc.
The software included with ECUTALK would also tell me things like A/F ratio, sensor information etc, correct?
It would be handy to know the tune it's running etc, if it displays all that info. I guess I'll check the website.
Yeah that's what I meant lol
Are there any particular fault codes I should ignore or look out for?
As the o2 sensor is a narrow band, it can't really show the afr, only when it is at 14.7 .
I think at the end of the day plugging in is pointless if the car is running well.
Okay no problem. I guess I will save myself 90 bucks then :)
  • 6 months later...
hey guys wanting to buy a Nissan consult cable to read/diagnose sensors/ faults/ codes (R34GTT) via laptop, is this cable the right one:
http://www.ebay.com/itm/Diagnostic-Interface-for-14pin-RS232-Cable-Consult-Port-for-Nissan-vehicles-Seat-/330900689074?pt=Motors_Automotive_Tools&hash=item4d0b37d0b2&vxp=mtr
thanks
Edited by rondofj
I bought something similar from ebay, and had problems with it, so I went and bought a PLMS one, have not had one issue with it.
http://www.plmsdevelopments.com/consult_if.shtml
yes doing the 'compression check' check via switching off cylinders and the the program monitoring the cranking differences in voltage can give an idea if there is anything serious going on. I did with mine before purchase (indicated less than 2% variance between the cylinders overall) and think it was a worthwhile check.
I think you need the full nistune license program for this. Also don't be turning up to inspect a car as your first time trying to connect to a skyline ecu via a consult cable. most people have a lot of comport and troubleshooting issues to get the connection working right the first time. (took me 3 hours of troubleshooting before I got it to work).
    • That’s a beautiful setup Tao, Have u done any development with the new Turbosmart 40mm electronic straight gate, especially in this G30 configuration?
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
