Howdy All,
I'm literally racking my brains on this one and I wanted to reach out and see if anybody had any ideas.
I fitted RB26 throttle bodies/plenum to my RB25NEO. Started it up, it was fine appart from head gasket failure. So removed the engine, did the head gasket. Put it all back together and now it starts and runs nicely but has this really bloody annoying whine!!
- It's coming from underneath the back/middle of the plenum.
- It doesn't appear to be coming from any injector (disconnected each cylinder and noise doesn't go away)
- It's there irrespective of fuel pressure
- It's there irrespective of whether the plenum is on or off (im running map sensor, so will run without plenum fitted)
- It's there if I remove the balance box/aac value and bipass the balance pipe
- I have swapped out the throttle bodies for another set. Still there.
- If you move the steering wheel to put load on the PAS pump, no change in volume or tone
- If you pump the brake no change in volume or tone
- It's there if you press the clutch
- It's there if you put it in gear
- It disappears if you rev cylinders 5&6.
- It decreases but is still audable if you rev cylinders 1&2 or 3&4
- If you rev the car with the plenum on, it goes
See the two video's below
Any ideas??
What do you mean by started up and was fine, apart from head gasket failure? Did the head gasket just somehow fail while you put on a new inlet? did it make that noise before the head gasket was changed?
The coolant was full of gunk, which I can only presume was something similar to radweld. I dropped the coolant, did the work on the car, started it up and the engine was mixing oil/water. I can only presume that the chap who sold me the car knew about it and threw in the headstop/radweld to get shot of it. The plugs were loose in the engine too. Bit of a mess.
Anyway - I seem to have isolated the problem. The adaptor plate was leaking air through cyl 5., causing high idle and the stupid sound (I hope) The inlet port on number 5 was full of hylomar sealant, where as all others were clean. I'm in the process of cleaning everything up, then i'll reassemble.
Fingers crossed and thanks for your help.
Chris
    • Well, if it wasn't a GTR I'd say that killing an RB is a perfect opportunity to put in a proper engine. In your case, proximity to Brabus and AMG V12s would be a no brainer for any RWD Skyline engine death event. In my case, because my car is my daily, anything that I do wrong that means I have to do it again is both an absolute pain in the arse (simply having to do it again), and also a doubling of the pain associated with having the car off the road to work on it. I would class a botched head gasket install as not being "engine death causing". More a case of "f**k it's still leaking!"
    • Yeah, this is more stuff like transmission/clutch R&R. Intake manifold R&R. It's not super complicated, but each step matters and you need to be careful and patient. I have heard stories for example of people not figuring out the super coppermix twin plate orientation and getting it wrong on assembly. Removing a cylinder head and putting it back in once it's machined isn't that hard, following torque sequence to install some cams isn't that hard either, but somehow I've seen a lot go wrong between here and there. Scraping off all gasket material isn't that hard either, but I've seen shops ruin heads by using a roloc disk that was too aggressive.
    • There is some shops in Germany that have quite a bit of experience with JDM performance 4-wheelers. I think if it actually comes down to it I'd let one of them do the head gasket. Killing an RB26 is too expensive a risk just to save some money by doing it yourself.
    • There are certain tasks, like replacing head gaskets, where it is very much best to already know what you are doing, and if you are not already an expert, then the next best thing is to have an expert around to help it get done. Little annoying checks and steps that are easy to forget or not interpret the results of properly, etc etc. It is hard to convey that to someone as a lesson prior to taking on a job, because there can be a whole list of "if you see this then it means that", or "if this is what you find then you will need to do these other 4 steps first". All the little bits of knowledge around sealant choice (ie, sealant at all? or no sealant? sealant only in certain parts of the gasket? sealant for this type of gasket but not that type of gasket? etc etc) cleanliness checks and methods, surface straightness and finish checks and methods, etc etc, all combine to mean that people who have done many of the same type of job will struggle less to get a good result than someone who hasn't done it before. I've been around this stuff since forever. But I will still consult with my expert(s) before taking on the big stuff with higher risk profile.
    • Well if I end up having to do the head gasket I will certainly find the necessary tools and instructions before beginning... Let's hope it won't come around.   Definitely. Depends on the job but I think "if you want it done right, do it yourself" applies almost every time
