hey guys i have just put a gtx 3582r and a geddy intake fmi and exhaust on my rb25 i cnt get it to stop idle hunting and running rich i have changed afm 02 sener tps gone over it for vak leak cnt find it im running a staned comp injecters and boost can anyone help thanks
https://www.sau.com.au/forums/topic/427445-need-help/
Either your AAC valve is not installed correctly (electrical/plumbing wise) or you have a vacuum leak somewhere.
Is this a Freddy manifold? If so, do you know that it is straight enough?
Are you running a PFC?
Note that this is a topic that has been posted about a kuntrillion times before and you should have searched.
Edited by GTSBoy
https://www.sau.com.au/forums/topic/427445-need-help/#findComment-6901674
are yes, but is that a metric or imperial amount
try running around the intake with a can of brake or contact cleaner, or the like, and see if idle changes and that will tell you if there is a leak
https://www.sau.com.au/forums/topic/427445-need-help/#findComment-6901675
i am new to this site and i havnt realy looked for the posted i will try now thanks
and xklaba i tryed that with contact cleaner didnt change anything and yes it is a greddy plenum if the face was not flat on the head shoudlnt it leak water from the jacket
https://www.sau.com.au/forums/topic/427445-need-help/#findComment-6901708
thanks GTSboy
even then on 5 psi with this big turbo how would it make it run so rich and idle hunt i have put 3540 on non turbo rb30 and its runs fine.
soon i will be putting my injecters in and cams and comp but there no reason that i can think of why it wouldnt run.
https://www.sau.com.au/forums/topic/427445-need-help/#findComment-6901805
been over it 100 times with water spray and contact spary doesnt change a thing i even pulled the intake off to make sure i have it all plumed up right couldnt fine anything. could a water temp sender do it. but then again it does it when its cold as well.
https://www.sau.com.au/forums/topic/427445-need-help/#findComment-6901868
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
