hey guys i have just put a gtx 3582r and a geddy intake fmi and exhaust on my rb25 i cnt get it to stop idle hunting and running rich i have changed afm 02 sener tps gone over it for vak leak cnt find it im running a staned comp injecters and boost can anyone help thanks
https://www.sau.com.au/forums/topic/427445-need-help/
Either your AAC valve is not installed correctly (electrical/plumbing wise) or you have a vacuum leak somewhere.
Is this a Freddy manifold? If so, do you know that it is straight enough?
Are you running a PFC?
Note that this is a topic that has been posted about a kuntrillion times before and you should have searched.
Edited by GTSBoy
https://www.sau.com.au/forums/topic/427445-need-help/#findComment-6901674
are yes, but is that a metric or imperial amount
try running around the intake with a can of brake or contact cleaner, or the like, and see if idle changes and that will tell you if there is a leak
https://www.sau.com.au/forums/topic/427445-need-help/#findComment-6901675
i am new to this site and i havnt realy looked for the posted i will try now thanks
and xklaba i tryed that with contact cleaner didnt change anything and yes it is a greddy plenum if the face was not flat on the head shoudlnt it leak water from the jacket
https://www.sau.com.au/forums/topic/427445-need-help/#findComment-6901708
thanks GTSboy
even then on 5 psi with this big turbo how would it make it run so rich and idle hunt i have put 3540 on non turbo rb30 and its runs fine.
soon i will be putting my injecters in and cams and comp but there no reason that i can think of why it wouldnt run.
https://www.sau.com.au/forums/topic/427445-need-help/#findComment-6901805
been over it 100 times with water spray and contact spary doesnt change a thing i even pulled the intake off to make sure i have it all plumed up right couldnt fine anything. could a water temp sender do it. but then again it does it when its cold as well.
https://www.sau.com.au/forums/topic/427445-need-help/#findComment-6901868
