My powerfc was tuned professionally and happily running the stock turbo for 4-5 years but the turbo has now parted ways, so i bought a hiflowed turbo, mistakenly thinking i could just keep the boost low and as long as it wasn't making more power than the stocker the tune would be roughly ok. Not the case, it runs really rich on or off boost(according to the wideband gauge)
Anyway now is not financially a good time for me to also get injectors,afm, heavy duty clutch plus the cost of another tune, so i was wondering (hoping) if anybody was willing to help roadtune the inj map to just get it running ok on say 10psi for now, i will get the afm now as its currently maxed out, but inj are only at 88% running rich so they can stay, i can offer some cash or a slab of your fav drink as payment for assistance offered, anyway just thought i'd throw it out there and sorry if it's offensive to ask such a thing from strangers.
a road tune requires a wideband 02 sensor and a competent tuner or a competent fiddler
its probably better off being done with a proper tune
if you plan on doing tuning yourself on your car buy a wideband 02 sensor and install it permenantly
then you can do it yourself
Yes i have already fitted the wideband i will need datalogit or fc hako and a suitable software program or if someone already has thise items and are willing to help then that would save me the trouble, otherwise where can i get the software from?
Your PowerFC is already tuned, it will just need a touch up tune because your boost curve has changed with a new turbo.
Make it safe, or you'll be spending a lot more in the future trying to get it running again.
I'll ask but i know on there website status state they don't adjust other peoples tunes they do a reset and start from scratch, i assume most would want to do the same, afterall new turbo and afm would be seen as major modification.
You could always ask a few tuners what a quick run-in tune would cost, something that could get you around on low boost until you save the rest of the coin. If they know you are coming back to pay the rest and finish the tune, they may be ok with it... It's worth asking anyway.
Something tells me Trent may be a little busy at the moment. :P
i have a full fc-edit (fc datalogit) kit for sale with legit software if you get stuck. $250 it is registered so updates can be downloaded and unlocks the diy tuner group on yahoo.
How long did it take before you could acess that online user group? They just ignored me after buying from them and sending through my activation email. :/
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
