Also i didnt want to start a massive debate over that comment but i did an aftermarket fuel pump replacement when i had my 33, had the bosch 040 put in and it didnt raise pressure all i wanted to know was what a good option for the 34 was.
Nismo drop in. Or a e85 400lph walbro will do the job Thetis drop in models for skylines on eBay for around $200ish. There is a 450-460lph version swell that's drop in. You may as well go a e84 friendly one for the future. :)
Cheers josh
Edited by Joshbigt62r
Cheers josh
pretty sure the e85 pump is not drop in. I have one, it is in but took some mods as it is a fair but bigger than the actual drop in pump, and it draws heaps more current.
I know the nismo pump is 100% drop in. The e85 460lph walbro make not be direct drop in but it is a intank fuel pump still. And still can be a drop in with a bit of basic mucking around. So yes it is a drop in fuel pump still as if drops into the tank. Just not a DIRECT drop in as the nismo pump is. keep in mind though the walbro is basically hAlf the price of the nismo.
Cheers Josh
Don't use the 040, the filter is prone to clogging and it is an old clunky design.
The Walbro 460L is overkill if you aren't tuning the car, even a Walbro 342 is more than you need, only costs $100, but still requires hard wiring the power.
I would be keeping the stock pump until you decide to tune it.
Chunky yes... I dont know why people use the 040 over the 044 as i ran an 044 with barb on the end and the original style fuel sock on the bottom of the tank, should solve that clogging issue... Worked perfectly and surprisingly wasn't loud! I blamed it for my fuel issues but it ended up being the injectors! I still run that same pump today but its now in the boot due to the external setup.
What does a 040 flow and what's a 044 flow? Sweet f all compared to the new walbro's
A single 044 got me too 350kw on an intank setup! How much power do you want to make? lol
I've got a single 044 that has been made to be a drop in. From memory I had to modify my cradle to make it a drop in. I put that in probably 5 or so years back. If I were to do it today I'd just use a walbro e85 friendly pump. Well plans are for me to make 400kw if I can. So I'll need to upgrade my pump. If memory serves me right the 044 flows 300lph but I could be wrong. 5+ yrs back memory not so great from regular weekend alcohol abuse haha. I'm more than likely still going a hta 3076r or 3582r on my built 25. Unless stao can come up with something pretty similar. Prefer to support a local bloke if I can. But FP hta just seems the ducks nuts at the moment lol.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
