Easier to just use 6 or 6.5" round speakers. Otherwise, like others have said, spacers or make a new parcel shelf from 10 or 12mm MDF board. You will then need to brace/mount it to the metal and then screw the speakers to the MDF.
Cheers for the feedback,
I am not running a sub but might consider a small sub in the boot with a small 100-200 Watt amp.
I did this kind of installation (on different cars) before but always had issues with noise from the alternator.
(actually running 2 amps and 6 speakers + sub)
But now with the Skyline and its battery in the boot this might not such a huge installation task.
Possibly a sub-box with an integrated amp would be ideal.
  • 3 weeks later...
I have 6x9 kickers i used 25ml mdf spacers and i just mounted them to the parcel shelf! had to take out the back seat and the rear trimming to get the parcel shelf out tho! And 6x9 don't distort maybe if you have a cheap deck!
I did this recently and to be honeat it was a huge pain in the ass. I have very deep 6x9's going yo have to look at a custom parcel shelf... I only did this because I had expensive 6x9's sitting doing nothing... if u dont have them laying around dont try it. Its simply not worth it.
Having said that this is in a gtr and I had bracing and battery mounts to deal with.
It looks like a dogs brekky . But im going to use it to build a new shelf.
Only thing I would say yo anyone hell bent on it is. Be patient and measure it out to the mm the tolerances ( on my install at least) are tiny
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
