Hey guys,
Just a quick question, where abouts would you get a respray done in Tasmania? Preferably Launceston area.
Story is, bought a CF bonnet up the southern outlet one night it blew up shattered my windshield and dent my roof. Sent it into MR Dingo for dent removal while i was away for 3 months. Came back dent removal was amazing, but there is now scratches and shit all over the place.... So just a head up can't fault his work, but don't leave your car there for extended periods of time!
Pretty much just want it all sanded back, any minor dents pulled out, if any rust is found get rid of it then resprayed the same color again (QM1) Bonnet will not be getting sprayed as its not worth the money (Bought it with holes in it, buying a new CF one to attach soon)
Anyone have any recommendations? Even if its a backyard job if they do amazing work i'd be willing to chat with them :)
Cheers, Zac
https://www.sau.com.au/forums/topic/427480-new-paint-jobs-where-to-get-it-done/
May i clarify, the dents were all fixed up, but there were scratches left near said repairs? or on other parts of the car? i'm not sure if Mr.untouchable does that work anymore since he's now soft and thinking of selling his car ;) but not harm in asking, he may be able to refer someone up north who can do the work as he's based in the south.
Mmm lots of love for my car lots of hate for me ATM lol. As for the re spray, what you want by the sounds of it is a 'closed door' re spray. Bonnet off door handles out, mirrors off etc moulds/trims off and some dents sorted and some primer here and there and some new white all over? Pretty simple task whites hard to get wrong, I would estimate 4k roughly at most body shops. The higher end shops might be higher but it's not a complicated job, just time and a bit of product. I'd be a bit shy of random backyard cashies some monkey with a barrel of acrylic could make a mess of it. I don't know of any good backyarders up their either sorry
Scratches where left all over the car, nothing to do with the repair job. My sideskirts took a beating, my rear end had scuffs and scratches on it. There is hairline cracks in the paint on the roof right near the edge.
No good man sounds like he had a party around the car while you were away. As Jack said I'd be wary of random backyarders as most will be happy to charge you f**k all but give you the same. Are most of the scratches really bad or would a good cut and polish tidy most of it up? If it's not scratched through the paint to the actual primer then you'd be amazed what can polish out. Shame your not down south or I'd be interested in having a look and giving you a quote.
    • I see... Any idea how much fab work is required? I note the Hygear megathread but its like 900 pages
    • I should try the experiment you're talking about, the throttle switch is still there carried over from the R32 and it's still all wired up but after I did the whole intake manifold refurb and had to recalibrate the TPS I managed to somehow get the idle switch reporting activation at 0.22V, then when I adjusted it to 0.45V for idle it decided the engine was permanently no longer idling which caused some very weird behavior, closed loop idle was disabled so it would basically be at the whims of the cold start valve and whatever the base timing table was at. Then just unplugging/replugging the TPS with the ECU live caused it to relearn the idle TPS position and decide 0.45V was idle. Presumably there's nothing in the TPS that allows for the throttle switch to "recalibrate" like that, not easily at least.
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
