Hey hey. Has anyone ever used or read these tutorials about changing the spark plugs.
http://www.sau.com.au/forums/topic/122284-r34-replacing-spark-plugs-on-neo6-rb20de-rb25de/
http://www.skyline-owners-club.com/forums/showthread.php?t=13449
Just wondering if during this process it's possible to replace the coils.cheers
You can't get to the spark plugs without removing the coil packs first, so yes it's possible
Just in terms of whether there was anything extra needed to know that could result in damages. But yes when replacing spark plugs the coils are indeed coming out. Just curious for sprays or lubrication or anything but it's all good.
Is a torque wrench absolutely necessary for the spark plugs?
No a torque wrench isn't necessary. No one that knows what they are doing would use one on plugs.
Having said that seeing as you have had to read are guide on how to replace plugs, perhaps you should use one to ensure you don't do them up too tight.
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
    • Sounds like the oil pressure light is wired into the oil temp sensor... As it warms up, resistance on temp sensor reduces, hence more current can flow and the dash light gets brighter.
    • Got the front subframe and suspension in.
    • If it's cold in summer, then no issue. If it's cutting out every few seconds and you're not reaching your target temp, then there's an issue. One could be the pressure switch and the other issue could be the temp probe inside the evaporator.
