If he's "porting and polishing" the head for $660, then he's really only waving a die grinder over it briefly to clean up a few casting dags and that's about it. Either that, or he's got no idea what he's doing and he's just going to hog it out. Refer to my first reply on page 1. I reckon a decent porting job can consume $2000 easy.
  • Replies 51
thats what i thought thats why i posted that up to show the quote broken down a little -
then i was looking at this -
http://www.lewisengines.com.au/rb-nissan-1/
step 1 and 2 this seem like a good price,
but i am seriously considering this
http://www.lewisengines.com.au/rb-30-25-torque-monster/
Looks like no porting on that one though , try supeflow heads at Liverpool I've seen a rb25 he was doing looked pretty good to me, wherever u go I think you are within your rights to see examples of work. Like in west ends case I know they do some of jems engines but I doubt they will tell you that. Ask who ever you go with exactly what porting and polishing you will get for the price
buy my head, it will save u alot. i got a fully prepped 25 head sitting on my workbench, fully machined for a 30 bottom end.
was gonna use it but i dont know if i can be assed to rebuild another motor.
just get urself a new set of lifters and ur good to go.
http://www.skylinesaustralia.com/forums/topic/422340-rb25det-head-modified/
i have a garret 35/40 at the moment but considering a change..
looking to run 360kw - 420kw.. may never get that hight but best to build motor to handle
Looks like a stock head would be fine with some Tomei cams
forget porting..my 26/30 makes 400 rwkw with 35r with stock head and stock rb30 block.
just buy this
http://www.ripsracing.com/catalog/Short-Blocks-37/RB30-Stock-Internal-Shortblock---2WD-10.html
or lash out and get the forged version
http://www.ripsracing.com/catalog/Short-Blocks-37/RB30-Forged-Internal-Shortblock---2WD-14.html
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
    • Well, no. It's an 023, which is pretty similar to an 040. Although it is hard to tell from the specs, as given.
    • Hmm. Maybe the (other thing I forgot about!) Haltech removes at least some, if not all, of the problem I described. I guess there is still the possibility of getting it wrong if the AC is set up/wired up for the Haltech as if it was in an R34 (simply because it's on a Neo), and that's playing foul with the R32 AC computer.
