I agree with AD. however still details missing, my advice separate the work Ie.. block + head, perhaps even send the block interstate. cannot recommend more Chilton Engineering in QLD. you will be very happy at the quality of work and the cost of it.
  • Replies 51
thanks guys -
i will gonna spend some time sourcing one out around sydney i think.. might look into melbourn and qld pending on shipping..
as everyone else i am after quality work and happy to pay for good work - just wasnt sure what i would be looking at..
thanks guys -
if anyone recommend anyone in sydney that would be appreciated
West end performance in campbelltown , he is very busy and may take 8 weeks or so but he does a fair few rb's including some for just engine management, anyway that's where I would go. I think from memory he quoted 4 k for all that plus crank linishing and all measurements for bearings etc. fairly aggressive head port and valve relief and setting head up with supplied parts including valve clearance etc 02-4625 4100. Super flow heads at Liverpool were around 2 k for ported flow benched head that looked pretty nice too. I went different direction but have had other engine types done at these places with good results, hope it helps you in some way
Can't go past JHH RACING either in woodbridge QLD. From memory. They are considered one of the best engine building shops in Australia. And you'll find a lot of the top performance shops send there customers engines there to be built.look them up or there fb page. :)
just gonna put this out there - i have asked for a few quotes from JHH racing in qld and some recommended shops in sydney and melbourn -
so far i have had a reply from -
shop in melbourn - $5500 this quote had a lot of extra little things detailed in the quote which i was unsure about
i also received one back from a shop in sydney for $2500 ( i have had good feed back from this shop from jap cars to 9 sec drag cars and burn out car - but this seems very cheap? - should i be looking into this more?
i am waiting on more quotes i just think this is a bit low -
below is what i have sent to a few shops.
I am looking at having-
Block -
- acid washed/ cleaned
- bored/ honed out for 86.5mm pistons
- top flat and level
- crank balanced
HEAD -
- acid wased/ cleaned
- port and polished
Pully to be re drilled and moved on the block and the VCT feed set up -
and engine put back together (ie pistons rods and head all bolted up) i will be doing all external bolt ons
i will be supplying all parts -
Probably ok for them mostly assembling it when I asked it was just measured etc but I would assemble, keep looking u will work out the correct number but when in Sydney go see him, he's always done good work on other engines for me, very knowledgeable guy too
Remember that the head work uses a lot of hours, and that proper, clean assembly of an engine involves lots of putting it together, checking clearances, pulling it apart and putting it back together again type stuff. Then you have the time spent checking torque figures and so on. It is easy to use up a lot of time building any engine, let alone one that someone wants to thrash.
The head is where the money is, setting clearances if they are lucky cams in check clearance cams out install custom shims cams back in and hopefully it's right. Then there's the porting, cc'ing combustion chambers, changing valve seats, guides, three angle cut blah blah blah, I rekon you could sink 39 hours in a head easy
wow - i new there was a lot and it aint easy but i think its more then i even thought.
i guess thats a top price for that many hours work..
in his quote the head was - HEAD -
- port and polished -$660 Service head -$350 Tappet - $220 Weld oil gallery - $150
then total assembly was about 2700 - thats the best price apart from the other one wich i think something was majorly missing
Edited by Reese69
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
