Hey guys
I've had my 33 since september last year, very standard and in epic cond.
Only mods at the time HKS cat back, hybrid front mount and turbosmart plumb back.
My main goal with the car is to make it responsive as possible
After my last car being a fail in most cases (listening to people that had no idea)
I talked to Powertune Australia, discussed the options for what im chasing in my budget to achieve what im after
they did me up a full quote and i told them honestly that i can get most things through my work for better prices and they were totally understandable
overall there customer service is amazing and from the results Ive seen with friends cars and on forums ill definitely get my tune done there.
here is my mod list of what i plan
- Garrett gtx3076 .82
- powertune highmount manifold
- tial 44mm
- walbro 400lph in tank
- deatschwerks 1000cc drop in injectors
- Haltech plug in, wideband, boost control and map sensor
- drop in camshafts 256*
- Forward plenum
and all the other misc stuff around it.
Here is the car when i first got it
After the first couple of weeks the car was due for its 100,000km service
it kinda blew out and we did a bit more then just a service..
- Apexi headgasket 1.1mm 87mm
- arp headstuds
- tomei poncams
- genuine water pump and thermostat
- godspeed forward plenum
- turbosmart supersonic bov
- cooling pro radiator (gates lower hose. gktech top hose)
- exedy HD clutch
- Blitz front pipe
- catco highflow cat
- custom cold side cooler pipes
- d1 spec breather tank
- greddy catch can (200 series fittings)
Heres a few photos of the car now with a new set of wheels and some tein super streets :D
Since then ive just been saving for the rest of parts and we are ready to go!
gtx3076
exhaust manifold
haltech
injectors
fuel pump
ill do an update when the rest of the parts are purchased and going on :)
thanks for reading!
https://www.sau.com.au/forums/topic/427514-dylans-r33-gts-t/
What sort of boost do you want to run?
Its hard to say as not too many people opt for the GTX series turbos, most stick with the GT series or recently the Force Performance HTA series (see 34geeteetee or lithiums threads).
Have a read of Angrys build thread, he was running a gtx3076r for a little bit before selling it for a twinscroll gt series.
http://www.skylinesaustralia.com/forums/topic/426934-angryrbs-r33-street-sweeper/#entry6888986
Its well known that at around 18-20psi you will see 300rwkw +- out of a GT3076r 0.82 with streetable response.
My GT3582r powered rb25 makes 330rwkw on 23psi, but its laggier than a gt3076r obviously. The GTX series turbos are laggier than their GT equivalents but they flow more, so ide say easily 300rwkw at those higher boost levels but its unfortunately going to be a bit laggier than a Gt3076r.
Also check out 6boost, ETM and Brae Fabrication for manifold choice, all steampipe like powertunes. Braes one of the newer lesser known producers but he has some epic designs, high and low mount.
  • Like 1
For a power figure ill let the tuner run what ever boost he wants, for everday use probably 14psi for low boost and whatever i can run for high boost
i've had standard turbo cars before, nothing like this car. if i seen 300+ id be cheering!
i was considering the gtx3582 but i wasn't keen on that much lag and down the track im going to be running a ethanol sensor for e85 aswell
my tuner told me id need to run at least -6 fuel lines under the car for fuel supply if i went with that turbo
for something that probably wont see a track i couldn't justify it
ill look into those manifold thanks dude!
I think the engine will be the limiting factor, I was using a stock manifold and at 16psi it was making 320kw's, with 20psi thru the midrange the car was angry, rolling on in second at 4000rpm it would leave solid black lines, third had the back end wiggling .. and that's not pushing the turbo at all.
other things id recommend
E85 walbro intank ( cheap and easy drop in)
Xspurt 1000's ( not too bad seeing you have ffp) mine at 70% with 320kw
gate off the housing
100cell cat
( just a thought but what about a TS manifold and swap the rear for a TS? )
100cell cat
Yours was on e85 with that power wasn't it?
That fuel pump I plan on getting
1000cc injectors are on the list
The cat I've got is 100 cell as well
Gate of the housing?
And as far as the rear housing ill probably leave it, I don't have any doubts ill be happy with the car
I've never had a fast car before and I'm not cheaping out on anything
So it should drive the way it's meant too and be reliable
He just means run the external wastegate directly off the turbine housing, rather than off the manifold. Better boost control and you can often also save a little bit on the manifold. All thats needed is for a pipe to be grafted and welded onto the turbine housing on a correct angle. pic below shows correct angle, where you can see the gate pipe is flowing straight up off the turbine housing where the gasses do not have to make any sharp or awkward turns.
(pic from and of nytskys engine build thread)
Thanks for explaining
Honestly I've never seen it like that before but I understand the concept completely
Ill defiantly consider it :)
  • 4 weeks later...
Hey guys
Not much to show, most parts are ordered
45mm turbosmart hyper gate
Walbro 400lph e85 in tank fuel pump
Full braided turbo line kit including drain
Haltech pro plug in, wideband kit and boost control module
Turbosmart fpr800 fuel pressure regulator
Powertune high mount steam pipe manifold
Genuine gaskets and exhaust studs
Only thing I'm waiting for is my 1000cc deatchwerks injectors
Getting keen :)
  • 3 weeks later...
  • 1 month later...
  • 3 weeks later...
Sorry it's been so long without a post guys been insanely busy
Went to powertune about 8 weeks ago
On 98 octane, 21psi it made 309.2 kw at the wheels!
Very happy with the result the way the power comes on is very smooth and controllable which is good as its my first car
Now I've got a lay by for a e-flex sensor and going down the track of e85 and dual maps :)
  • 7 months later...
Hey guys!
It's been a while been flat out with work and stuff
The skylines going really well, the only problem
I WANT MORE POWER!
I've picked up a second hand block, considering building it and a head.
I'm uncertain what path to take
Is the car going to be reliable stock on a flex tune pushing more on e85?
If so does anyone know what kind of number I'd be looking at??
For now I'd love to do upgraded fuel and run a flex sensor to get more out of the current set up
But long term I definitely want a fully built motor :)
My goal would be to max the gtx3076 .82
After recently going for a drive in a friends gt35 powered 33 I don't think I could deal with the lag lol
  • 3 months later...
