Up for reluctant sale is my beloved r34 gt-t as i have only 8 weeks to go before our first child is due to be born. Car is serviced every 5000km. Used on the weekends as i have a work ute. This is the most reliable car I have ever had, has been from adelaide - brisbane return, sydney * 2 & melbourne, easiest long distance cruiser. Only run on 98 fuel and was tuned at Boostworx.
A change from the photo is that it is now fitted with a Yellow top Optima Battery
11/1999 R34 GT-t2.5Lt turbo 5 Speed Manual White
150000km
Only Australia owner , imported in 2006 completely unmodified and have nearly all the original parts.
Engine and Drivetrain Performance Mods
HKS DD Air filter pod
Nissan Z32 Air Flow Meter
Garrett GT30 ball bearing turbo
HKS Front Mount Intercooler
HKS SSQV blow off valve plumbed back
Tomei Poncam Stage 2 256 degree in/ex camshafts
Sard 660c injectors
Nismo high flow fuel pump
Splitfire high performance coil packs
APexi Power FC with Hand Controller
GReddy Porfec B Spec 2 boost controller
GReddy timing belt
Nismo N1 water pump
Exhaust Technology Front dump pipe
3” High flow metal cat
3” HKS HiPower cat back exhaust
Exedy racing light weight flywheel
Exedy Hyper Single 3 puk spring centred clutch
Lenso GF7 Rims 19*8 with 235*35 front Kumho KU31
19*10 with 275*30 rear Kumho KU31
Car has been tuned on 17psi and produces 285kw at the wheels and still achieves 10.5L/100km on a country drive.
Stereo
Alpine IVA-D310E 7” touch screen DVD, MP3 head deck
Focal 6” splits in front with custom mounted tweeter in mirrors
Focal 6” 2 way in rear parcel shelf
2 * Focal 11” subs in custom carpeted box in the boot
Audison SRx3 500w amp in custom made carpeted surround
Sound deadened rear parcel shelf for less vibrations
Stereo built for high clarity not for loudness but still loud enough
Other
Laserline alarm with 3 immobilisers, ultrasonic shock detectors, tilt sensors, turbo timer mod, remote boot release, auto window windup on locking
All lights wired through ignition so can’t be left on
GReddy Full Auto Turbo Timer
Blue neon light in boot as standard light is behind sub box
$17000
0407910845post-44616-0-04163300-1372061759_thumb.jpgpost-44616-0-39100200-1372061870_thumb.jpgpost-44616-0-76734600-1372061900_thumb.jpgpost-44616-0-25141300-1372061935_thumb.jpgpost-44616-0-90996200-1372061994_thumb.jpgpost-44616-0-83317900-1372062005_thumb.jpgpost-44616-0-15822400-1372062015_thumb.jpgpost-44616-0-63023000-1372062020_thumb.jpgpost-44616-0-27036100-1372062026_thumb.jpgpost-44616-0-90766200-1372062032_thumb.jpgpost-44616-0-37416600-1372062038_thumb.jpgpost-44616-0-77814700-1372062045_thumb.jpgpost-44616-0-38716100-1372062052_thumb.jpgpost-44616-0-56574300-1372062059_thumb.jpg
I think you will struggle to get much interest at 17k mate, might take a fair while to sell at that price. If you think the car is worth it you just have to wait it out.
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
