Hey all,
I'm going to be replacing the head unit in my v soon for obvious reasons. I was wondering if it is worth replacing the speakers at the same time?
I'm just wondering how difficult is it to remove the head unit once an aftermarket one is installed. I will be getting a pro to do the hu initially but if I want more after is it easy or a royal pain?
I don't really know how good the stock system is because of the appalling standard hu.
Any thoughts, comments, suggestions?
While I'm on it, got any suggestions for a good hear unit somewhere around d $500 mark?
https://www.sau.com.au/forums/topic/427563-speaker-replacement/
I'm running an aftermarket head unit with the stock bose system, and I'm happy with it.
Every other car I've owned had my focal 6.5 inch splits and a big amp installed, with copious amounts of dynamat, (I have to admit it sounded particularly good in my AE111 Levin considering the interior of the car was tiny)
The V35 is probably not as good, but its close enough that I'm not replacing the stock speakers until they die.
If you don't have the bose system, I'd probably replace it all
Agree the bose speakers are not the best thing you will ever hear but defiantly better than cheap pioneer kenwood ect so upgrade to really good speakers, if there is somthing wrong or your really really picky! my advise would be to still add an amp and sub to the boot, that combo sounds great with the stock speakers
Appreciate the info guys. Is it hard to add more cabling to the headunit after its been installed though? The guy who's doing it was going on about having to wire in the climate control and such, I don't want to have to go through that everytime, or do I have no choice?
if you buy an aftermarket double din, the wiring goes to that not the head unit. so the hard part is already done. i had my head unit out to plug a new aux cable into the back the other day. it took me less than an hour. so shouldn't matter when your putting speakers in. but if you where to do it properly id just run a spare rca to the boot now so you can plug amps in later. as for good aftermarket speakers you need a good amp!
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
