My gauge sits pretty much at 0 almost all the time when I'm driving around normally. Only time it would go up is under hard acceleration or slippery conditions. As soon as it's disabled, rear wheels spin. So my system works, maybe not as lively as a new one (haven't flushed/bled it), but it still works after 20 years. I don't see any reason it should be sitting above 0 during as it's not meant to be transferring (as stated).
If your gauge is above 0 all the time, you have problems, unless you're thrashing it literally all the time. Pretty simple and obvious.
Note that your ATTESSA is being worn out a lot quicker, they're not designed to run all the time. Direct experience, my system randomly craps out now (warning lights, hissing from transmission, system disabled, have to power cycle the car, needs a bleed at the very least). Before I put mismatched tyres on, it worked fine with no issues.
  • 2 months later...
yes you were right put 245 all round 4wd read 0 as all my other gtr and my old gts4 did!! rims sizes turned out to be 9.5" and 10" but you still see the different stretch even with 245 40 18 tyres , im running 35psi in the front and 40 psi in rear . only have 2mm guard clearance in the rear tho :devil:
thanks blind_elk you were on the money!! also to everyone else
ps torque meter reads dead zero when cruising and under light-med acceleration unlike before - major difference!! so now my rwd switch is not always on = less fun & better power to the ground
How many f*****g times do we have to state that you need same size tyres on same size rims on all 4 corners?
Stretching a 235/40 tyre onto a 10" rim will force the rolling circumference of that tyre to be smaller than a 235/40 on a 9" rim. Result = ATTESA chaos.
The added advantage of this setup is that you can easily even out tyre wear by swapping F<>R at regular (say 5k) intervals.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
