Hi guys, need a bit of help on this. I've got 2 options basically:
1. Get a cheap r32 gts4, transplant a 2.8stroked rb26 with 2530s and support systems.
2. A minimally modded (intake,exhaust) r32 gtr with about 140ks.
Which one would u choose and why?
What other differences are there between a r32gtr and r32gts4 apart from the engine? I know the gts4 is lighter and apparently the gearbox has a shorter ratio. Can u tell me some more?
Thanks tremendously
https://www.sau.com.au/forums/topic/42760-huge-dilemma/
how much do you think a stroked rb26 with bigger turbo's will set you back? (including the cost of the conversion, and support systems).
at the end of the day option # 1 will still be a gts-4. so you wont have the decent brakes, seats, flared gaurds, different atessa system etc. and you will also have poorer resale value.
https://www.sau.com.au/forums/topic/42760-huge-dilemma/#findComment-873572
hawks, ive got a running fairly good condition gts4 at 45k and a 2.8Lrb26 with hks2510s around 15k, labour will be max around 3k.Planning for r33 brakes, support will cost round 10-15k.
r32 gtrs here valued at 100-120k depending on mods + condition.
Looking at a bargain one at 85k (mild mods). Still, it's a gtr :rofl: but im not that happy to spend another 20+k to get it to around 550-600bhp where i want it
https://www.sau.com.au/forums/topic/42760-huge-dilemma/#findComment-873581
okay, put it this way. i'll give you the example in aussie dollars.
option #1 gts-4 approx $15-20 grand
stroked rb26 with larger turbo's and box and fuel system, exhaust, brakes, labour etc approx $20 grand
option # 2 a decent r32 gtr maybe with a few basic mods $35 grand
at the end of the day you could have either a modified gts-4 worth about $20 grand or a gtr. i would take the gtr thanks.
https://www.sau.com.au/forums/topic/42760-huge-dilemma/#findComment-873582
Thanks tremendously
Gobiz;
What do you want the car to do? Street cred/drag/cct race/motorkhana/daily driver or something else altogether?
https://www.sau.com.au/forums/topic/42760-huge-dilemma/#findComment-874786
the gts4 has the same attesa system as the GTR. the differences are the brakes, flared guards, interior is different, wheels, engine, gearbox is same box weaker in GTS-4. and thats about it, i have a 4 door GTS-4 so it looks like a normal everyday car ( sleeper ).
https://www.sau.com.au/forums/topic/42760-huge-dilemma/#findComment-875699
Yeah, and you'll never get over the look on the guys face in the GTR at the drag strip after you leave him in your wake of your $20k GTS4.
Who cares if its gts4 or gtr or gts-t for that matter, if its a skyline with a rb26 and 2530's, it will haul, end of story.
Any skyline deserves respect.
https://www.sau.com.au/forums/topic/42760-huge-dilemma/#findComment-876451
You are right, the gearboxes are absolutely identical, ratios and all. The R32 GTS4 with the RB20 has the different lower gear ratios. The R33 GTS4 is the same as all the GTRs.
I looked at this GTS4 vs GTR thing myself a while back, it is a tough decision. At the end I suppose it depends on what you really want. If you want a GTR, only the real thing is going to satisfy that......
But if you want a great sleeper, a GTS4 with stock four stud wheels and stock on the outside would make a great street sleeper. You are a lot less likely to have it vandalised or stolen as well.
https://www.sau.com.au/forums/topic/42760-huge-dilemma/#findComment-877315
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
