Because I like stupid things I bought some of these from china
I can confirm they are awesome
If anyone wants one I have a few spares( you can't buy only one from china)
great for grass or dirt driving, with a gutsy four-stroke 6.5hp OHV 198cc engine.
Unlike most karts this size it feature electric starting, with a pull-start back-up.
The kart is supplied with semi-slick tyres, plus an extra pair of knobby tyres for wet grass and muddy conditions.
The aircraft-style steering wheel has the throttle lever on your right hand and a hydraulic disc brake on the left.
Here are the key features of the Kart:
198cc OHV four-stroke engine
Electric start and pull-start back-up
Hydraulic disc rear brake wit cross-drilled disc
Aircraft-style steering wheel
13-inch tyres designed for sliding
Heavy duty frame with sprung rear suspension
Race seat with padded cover
Lap-type seat belt
Roll bar with pads, sun shade and two rear view mirrors
Tool kit and full instructions for assembly (takes around 1 hour)
Runs on regular unleaded (E10 not suitable)
Only available in blue.
Suitable for riders up to 185cm tall and 100kg. Not recommended for children under 12 years.( in saying that I am 6'5 and 140 kegs and I just fit)
Helmet and protective clothing must be worn. The roll bar will not protect you in every conceivable accident, it is only intended to stop the kart landing on you if you tip over.
Comes with a 6-month warranty on engine and frame (wearing parts such as tyres, clutch, brake pads, air filter not covered, damage caused by accident or abuse not covered).
All spare
Pete
https://www.sau.com.au/forums/topic/427609-off-road-go-kart-999-new/
Can be disguised (somewhat) as a 4W Scooter at my Aged Care Centre right?
Hanging triangular SAU flag off the back > Get TE37s > BTW tyres easy to get?
Chinese Blue lead paint - like on Mattel toys? Racially, I'm allowed to ask that!
How cute!
How hilarious!
Am indeed tempted - going to think this over...
How cute!
How hilarious!
less thinking and more hooning. :yes:
If anyone is in the mountain around 230pm today swing over we are having time trials in the yard
Do it don't be a pussy
Apparently they are rated to 100 kegs. So far so good and I am 140 kegs......
Lol I have found the bump stops a few times
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
