Just buy the very best your budget will afford.
Michelin will be good, so will Pirelli, dunlops, continentals, then you have the next tier down, like kuhmos, hankooks, etc, before you reach bottom ling long china spec which really don't rate a mention if your after a decent tyre.
https://www.sau.com.au/forums/topic/427637-v36-tyres/#findComment-6905607
what size you need?
I have some Hankook Evo V12 225/40/18 and 245/40/18 and they are amazing. Brand new, i had a set in 19" and wow the thread life, grip, wet grip were amazing. Almost as good as Michelin Power Sport 2 which are 2x price.
Where do you live? I have the set for $800 obo
https://www.sau.com.au/forums/topic/427637-v36-tyres/#findComment-6905830
I'm growing a little tired of our Australian market not considering our tyre sizes to be within their minimum volume requirements. Given the specifications from Nissan, it'd be nice to have the correct spec tyres to suit. It's actually tempting to consider buying them from the US.
https://www.sau.com.au/forums/topic/427637-v36-tyres/#findComment-6905895
My continental tyres corner at a higher G in the wet than the hankook evos can manage in the dry on the same car....
Thanks for the link, interesting.
I now run the RS3 and my mate uses them in the Time attack series, as do alot of other competitors.
If they can handle springbrook and mt nebo they can handle daily driving for a sedan !
My point was when comparing to other tyres in the same price bracket they are amazing tyres.
2 reviews
http://www.modified.com/tech/modp-0904-hankook-ventus-v12-evo-k110-tire-review/
Came 2nd in a 10 tyre shoot out
http://www.caranddriver.com/comparisons/hankook-ventus-v12-evo-page-10
https://www.sau.com.au/forums/topic/427637-v36-tyres/#findComment-6905921
Even the RS3s aren't a real semi slick. They are in the same boat as federal RSR, KU 36, to some extent AD08. They are a ling long (see what I did there....:P) way off real semis like Z221, A048, R888/NT01.
Anyway, too off topic now, buy the best your budget will allow!
https://www.sau.com.au/forums/topic/427637-v36-tyres/#findComment-6905933
Even the RS3s aren't a real semi slick. They are in the same boat as federal RSR, KU 36, to some extent AD08. They are a ling long (see what I did there.... :P) way off real semis like Z221, A048, R888/NT01.
Yes off topic haha, my point was for the money the hankook evo v12 are alot of tyre for the price. Esp if u pick them up new for what im selling !!! :)
PN-Mad, i agree most of the time with what you say and always hope you will help me with my turbo issues ! but no way RSR, KU36 or 888 are close to RS3, they are destroyed on the track. RS3 are on par with AD08, Z221, i dont know what A048 is, RE11 is the only one i would say outperforms them in that group. I wasted hours and hours reading experiance based racing threads on the use of RS3 Vs Z221 Vs RE11 Vs AD08. That friend i was talking about, 58sec lake side Evo 8 swears by RS3, alot of the guys in time attack use them. But back to topic, let me know if i can help out with the tyres ! :)
Edited by R6n350GT
https://www.sau.com.au/forums/topic/427637-v36-tyres/#findComment-6906106
    • If you do go with drain back, make sure everything is foam or wool filled so it actually does something, and ensure there is a screen somewhere in the drain to catch anything that comes loose from the packing. I don't drain back
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
