Hey guys, im guessing this has been roughly covered before but did some searching and couldn't get a definitive answer.
Im after some info on piping size I should run.
im putting a 3076 or 3071 on 6boost mani with a r34 gtr front mount so its got 3" inlet and outlet.
im also getting a plazmaman with new tb of whatever size I need.
im looking to get 300kw or just over atw with minimal lag so I don't want to go 3" piping if itll just add lag.
what I was thinking is 2.5" from turbo to ic with a reducer and then 3" from ic to the tb and obviously get a 76mm tb
will this be the best way or should I just keep it 2.5" all the way and use reducers either side of the gtr ic.
Stock throttle body has the traction control butterfly on it which is gaids for a FFP installation. Either obtain a new TB or a TB from a Stagea Neo. Note that factory ECU+Nistune is barest minimum to permit that sort of change. Standard ECU will of course have kittens if left to itself.
johnnilicte - how much more lag am I looking at, surely not much being still on the standard runners..
GTSBoy - Im ditching the traction control, and as stated purchasing a plazmaman throttle body.. and I already have a power fc
scotty nm35 - pretty sneaky there, never even thought of running it that way, probly not the best for flow though..
any way of making the hole through the side look standard like a gtr, im going with all black plenum and piping for that reason
It flows better than a return flow, and less piping.
I never understood why the pipe goes underneath the cooler in the return flow setups, and the core is always hiding up behind the intrusion bar. Not good for cooling imo.
around 200~300rpm, have a look at the dyno charts on the RB25 turbo results
I had my return flow custom made (in 2000!!!) and we put the return pipe behind the reo. Core is using the whole opening of the GTR bar. Very successful.
btw johnnilicte im thinking of getting a custom plenum still on the standard runners, possibly a slightly smaller one would let it spool up earlier than the 5.5L capacity advertised by plazmaman??
if I get a custom one it will most likely be from racers choice, a local fabricator..
I want to go forward facing to tidy it up a bit and make plug changes easier
Just get the Plazmaman one, it's nicer.. most other fabricators use sharp edges etc... where as the Plazmaman one is nice and smooth promoting better airflow...
I still say stick to the stock one, unless you're chasing 350kW+ :)
Look at AngryRB, he's made over 320kW+ on the stock one.
Yuh, the whole "nice and tidy and easier plug changes" thing is a bit of a tired line. You only need to change plugs infrequently, and it is no more than 15 minutes work to get the crossover pipe off if you have to.
There are distinct negatives associated with FFPs (usually they cost response and the cops love them), with barely enough positives to justify....for a street car. On a race car, go right ahead and spend your money.
I already spoke to the guy, hes a friend of a friend, said he would do a good price (less than plazmaman) and has the machine to roll the alloy so it will be rounded like the plazmaman.
I know the plugs aren't that much of an effort, but it just looks heaps better than the pipe coming out and then swinging back over the top of the motor.. im hoping to have everything black so as to not draw too much attention when the bonnets open
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
    • Stock O2 sensors are narrowband. They're useless once you're away from stoich. IE, useless for what you're trying to do. 10:1 will read the same as 14:1 from the stock O2 sensors. That is, they'll read rich. The same level of rich.
    • I agree once misfires happen it's basically worthless, but the hope is you can see what's happening in the run up to that.
    • You should totally get a Brumby, and then come pick up the Subaru Liberty GTB I have here. EJ25 Turbo, 6 speed manual from the sti (just no dccd), and the good rear diff. Drop all that into a Brumby and go have fun!
