Tomei Poncams (type a) 256deg 9.5lift in and 260deg 9.5lift ex
Great condition
$500
Garrett dash 5s turbos aka hks 2530s
With adjustable actuators
Also come with the modified oil drains that is needed for bb turbos
Direct bolt on kit
Comes with everything
$1500
Garrett dash 5 core centre great condition
$350
Gates racing adjustable cam gears for rb26/rb20
Like new
$180
Gates racing timing belt
Like new comes with tensioners
$40
Tomei sump baffle for rb26
Like new
$150
N1 oil pump
Like new great condition
$150 can put billet gears in for extra
N1 water pump
Like new
$100
Rb26 greddy clear timing cover
Great condition
$70
Rb26 valley cover painted wrinkle red with new 34 gtr ornament plate
Looks awesome
$100
Rb26 head complete with cams etc covers painted wrinkle red like nismo
Great condition
$1000
Rb26 crank long snout r33 came from running motor
$350
R33 Gtr injectors
$150
Rb26 complete intake plenum set up
Throttle bodies, adapter plate wrinkle coated plenum black
$300
Rb26 sump and diff
$150
Rb26 alternator
$50
Rb26 rods great condition
$50
Rb26 pistons
$50
Rb26 oil drains from the blocks
$40 each
Rb26 oil squirters
$50
Many other 26 parts available
Gold Coast
0487924497
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
    • Nice, is there a post with the new 4" dyno curve?
