Tomei Poncams (type a) 256deg 9.5lift in and 260deg 9.5lift ex
Great condition
$500
Garrett dash 5s turbos aka hks 2530s
With adjustable actuators
Also come with the modified oil drains that is needed for bb turbos
Direct bolt on kit
Comes with everything
$1500
Garrett dash 5 core centre great condition
$350
Gates racing adjustable cam gears for rb26/rb20
Like new
$180
Gates racing timing belt
Like new comes with tensioners
$40
Tomei sump baffle for rb26
Like new
$150
N1 oil pump
Like new great condition
$150 can put billet gears in for extra
N1 water pump
Like new
$100
Rb26 greddy clear timing cover
Great condition
$70
Rb26 valley cover painted wrinkle red with new 34 gtr ornament plate
Looks awesome
$100
Rb26 head complete with cams etc covers painted wrinkle red like nismo
Great condition
$1000
Rb26 crank long snout r33 came from running motor
$350
R33 Gtr injectors
$150
Rb26 complete intake plenum set up
Throttle bodies, adapter plate wrinkle coated plenum black
$300
Rb26 sump and diff
$150
Rb26 alternator
$50
Rb26 rods great condition
$50
Rb26 pistons
$50
Rb26 oil drains from the blocks
$40 each
Rb26 oil squirters
$50
Many other 26 parts available
Gold Coast
0487924497
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
