Hello everyone,
I ran a search and couldnt really come up with any deffinitive answers. I figured I'd start a post here to see if anyone had any advice and I will be updating with remedial actions. I'll start off with the car specs and then run you through the situation.
1992 BNR32 GTR, 108,000 km on stock RB26DETT
Mods include: Power FC, HKS pod filters, Koyo radiatior, HKS intercooler with hard pipes, ORC twin plate clutch.
The other day i took my car past 6000 rpms for the first time and the cat temp light flashed rapidly. after some research i learned that the powerfc will flash the cat temp light when there is a red flag for multiple reasons. One of them being engine knock.
I changed the display on my powerfc to display engine knock and found some disturbing results. At start up, the fc will read a high of 30 knock. After start up ill clear the display and at idle it will show knock between 1-8. normal diriving up to 3500 will show 8-15. 4500 will show 20-25. at 6000 it will show 61. My power fc is set flash the cat temp light at 60 nock so that would explain why it was flashig.
From my research I've learned that the Powerfc is not the most accurate device in displaying knock, and should only be used to give a general idea. I guess all im asking is what do you all think of this? How concerned should i be? I would rather have ZERO knock lol.
This weekend I will be compression testing the engine to get a better idea of where i stand. Hopefully the results wont be to bad. As long as its not to bad (155-175 psi on all cylinders) i plan to baby the car for the next two years and save $ for a new engine.
Any thoughts or advice is welcome. Thanks guys,
-Eric
I wouldn't be worried about 60 knock at 6000rpm either.
"i plan to baby the car for the next two years and save $ for a new engine". Good idea to plan for a rebuild.
Read up on the well documented oil starvation issue caused by the short nose crank, crank collar, OEM oil pump and subsequent failure of Big end bearing/s.
- Pre late 93 model R32 GTR's
This post is not meant to cause you undue concern, but rather give you information so that your aware, if not already aware.
Edit:
my compression test came back at 154 to 155 across all 6 prior to when I bought my 92 GTR in 2004 at 104,000kms.
Oil starvation and big end bearing failure within the first few months of ownership. I wasn't aware of this Achilles heel at the time.
Oil pressure gave no indication prior to failure.
Edited by Sinista32
Thanks for the heads up Sinista,
I have done some research on the Achilles Heel of the RB. My compression test didn't come back all that great...
1: 149 4: 149
2: 145 5: 145
3: 140 6: 140
lol planning for a rebuild! :thumbsup:
I believe the 2nd reason is
R32's restrictor in the head feed is too large and the return too small causing all the oil to stay up in the head too long and leaving nothing in the sump - Big end bearing Doh!
Most over fill a stocker by a half to a litre if they take it to the track.
I take it this was resolved in the 33?
Here say - I've also been given to understand the bolts attaching the oil pump can work loose causing failure.
There could be more reasons so I'm interested to hear also.
OP - just keep driving. With a safe tune and enough good oil that motor should last. Make sure the oil is never below the high mark, and if you track it, fill it up to the bottom of the top bump on the dipstick (IIRC about an extra litre). I have a 1990 and have tracked it plenty of times with no issue. The only fix i'm aware of in later 32s is the longer oil pump drive on the crank. There is a clear error in the design of the early cranks, but if you have a working harmonic balancer and dont limiter bash, it should last. I dont know of any design changes to fix oil starvation in the rb26's life.
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
