Guest Robo's
Well finally did it at Calder tonight with my stock turboed R33 GTST running street tyred Sumituno's HRZ'2's with a [email protected] with a 2.02 60 foot. I was completely wrapped.
First run saw a PB of [email protected] with a 2.09 60'foot. Next run was surely a 12 second run with a 1.97 60' foot but missed 3rd gear and coasted to a 13.6. Then the final run of the night saw the above result [email protected].
All this result with the standard turbo running 13psi, still using the trusty SAFC, FMIC, Full 3 inch exhaust, Boxed up Pod, and cam gears.
Got to be happy with that :rofl:
https://www.sau.com.au/forums/topic/42767-r33-into-the-12s/
  • Replies 123
Good Job! Best I could get out of my stock turboed RB25 was a 13.8 @ 104 with a 2.1 60ft. Of course my RB25 is in an S13 body so I should be a little quicker. I am running stock IC, stock ECU with no fuel correction and 3" exhaust. Looks like cam gears and SAFC should be on my list of future mods.
https://www.sau.com.au/forums/topic/42767-r33-into-the-12s/#findComment-873475
great effort robbo it means a 12 is not far away for me either had a similar mph with less power than now.
calder seem to have made the surface much better for launching heard of some great times last night dr-drifts ca datto 1600 ran 12.003 @ 113 mph on street tyres and he did a 1.7 60'. also a gtr did 11.6 @ 120 mph.
meggala
https://www.sau.com.au/forums/topic/42767-r33-into-the-12s/#findComment-873518
Awesome! Congratulations, thats very impressive without heaps of mods. In NZ the quickest R33s are barely touching into the 13s :rofl:
I'm just a n00b here, but I have been quietly tracking your progress and soaking info, because I have been building up parts for my R33 - and your car for a while had very similar to the mods I decided to do for my "first stage" (cold air intake, cat back exhaust, and S-AFC2) and read quite a few posts re: your car and S-AFC tuning which looked very positive for the direction I was heading.
What clutch are you running?
https://www.sau.com.au/forums/topic/42767-r33-into-the-12s/#findComment-873545
Guest Robo's
Running the Extreme Daikin Heavy duty. Its been in for nearly a year now with about 20 runs down the strip and not one problem. Not bad for $400.
https://www.sau.com.au/forums/topic/42767-r33-into-the-12s/#findComment-873593
Good to see another std turbo r33 into the 12's, still not sure where im gonna find a full 1sec but it'll be fun (and expensive) trying :rofl:
R33vit ran a 12.9sec on the std turbo with a "road tuned" P/Fc which is extremly impressive too.
https://www.sau.com.au/forums/topic/42767-r33-into-the-12s/#findComment-873716
No, not at all - I haven't had any problems with mine at all... but so far I have only been running around on stock boost, untuned SAFC and a catback exhaust - so no real stress for it YET :P I run 255s on the back so I am a bit worried that after the car is tuned with a bit more boost - it might get a bit more upset.
Anyway, keep up the good times guys! I'll watch with interest how you guys are going and see if I can get an R33 representing a little in NZ as well :rofl:
https://www.sau.com.au/forums/topic/42767-r33-into-the-12s/#findComment-873744
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
