I've noticed recently that on 3rd and 4th gear when I push it to just past 3k rpm the car violently jerks. It almost feels like the engine just cuts out and then comes back into play.
What could be the problem here?
https://www.sau.com.au/forums/topic/427732-cold-run-jerk-at-3-4k-rpm/
Airflow cut.
Or your girlfriend getting excited, sometimes they can't wait to get home... Those were the days...
This might be a stupid question but is it a major problem and how much am I looking to get it fixed?
LOL. My girlfriend doesn't drive a manual.
If the car is stock, the AFM could need re-soldering. If it is modified you will need to let us know the mods, and what, if anything was changed recently.
The only mods it has is a K&N air filter and a full 3" exhaust system (Don't know what brand) and that's about it really.
Try cleaning the AFM first, if that doesn't fix anything, try the re-soldering trick on the afm (there is a how to here) or borrow another one to try.
How old are the plugs?
Sorry I'm really new to skylines so what is an AFM?
The 'air flow meter' it is the black plastic tubing before your k&n filter. With the wiring coming out.
Easy to remove. Recommend searching for the diy on cleaning and soldering afm
I can't seem to find the afm. Do you have a picture that could help me out?
if you cant find the afm then the chances of you fixing the car yourself are limited at best
suggest employing a qualified mechanic to sort the car out for you?
do you know how much boost you are running or if you have a guage what it hits just befor the cut
Unfortunately not. Just replaced my air filter though and the problem seems to have disappeared. Might be getting a gauge in the near future though so its easier to diagnose problems.
