So ive got a 98 Non turbo R34, i had one coil pack go a few months back and replaced it, since replacing it i noticed when i started my car occasionally it would die unless i keep some revs on it for the first few seconds and would usually stay jumpy around 700 instead of steady on 1k revs . i thought this could be the spark plugs or other coil packs because im just under 100,000 k's so i went and got a set of 6 coil packs that were off a low k's 34 in perfect working order and some new nismo spark plugs 0.8 heat range 7. fitted them all, noticed a vacuum purge in one of the rubber grommet seals on my rocker cover fixed that and put everything back together but problem still there. i just replaced the O2 sensor a couple months back so last thing i could think of was the fuel pump, got a new one fitted and same problem and now i also have an occasional put put sound that comes through the exhaust. sounds like the timing of the engine is off
and now im out of ideas on how to get it running mint again
i have a video of the car struggling to start
http://www.youtube.com/watch?v=pvNUk18iGX4&feature=c4-overview&list=UULMTc8BU-SPQo_YbXqXHwpg
and a video of the put put sound, its kind of hard to notice it through the recording
http://www.youtube.com/watch?v=1c31tleK8GM
has anyone gone thought this or have any ideas on what else it could be
  • Replies 45
the put put tends to happen mostly when its cold, but the struggle for ignition happens when ever i have to start the car, once i start driving it feels almost normal besides the occasional slight put put that goes through the exhaust. i haven't driven it much since these problems have come up just been taking it from mechanic to auto electrician
Get six BCPR6ES spark plugs (they are like $3 each), gap them to 0.8mm (they should already be 0.8mm so check the gap), put them on and see how the car runs. Sounds like failing coilpacks unfortunately. Could be the other ones starting to die.
I put yellowjackets on my R32 GT-R, the slight miss on idle is gone and revs noticeably better. I use 1.1mm plugs now as well (better spark, BCPR6ES-11).
ok ill grab six BCPR6ES spark plugs tomorrow and chuck them in as well as put the original 5 working coil packs from factory + the 1 i bought to replace the the first dead coilpack (bough from nisswreck and confirmed working by my mechanic) and see how it runs then,
does it matter if you run cheap spark plugs? or does it just mean youll be replacing them more often?
and with the new spark plugs i guess i should get heat range 6 too?
thanks for the help
ok so i did as said above and it solved those two main problems perfectly! thanks so much for that!
although there is still the slight loss in rpm when in neutral and i slowly rev, the revs will increase as usual but then will drop off slightly. it only happens around 1,800 rpm as far as i can tell
heres a video that shows it happening, you may need to turn your sound up yo hear it
http://www.youtube.com/watch?v=i81v3nyLurY&feature=youtu.be
anyone have any ideas on why this would happen? maybe something to do with the aftermarket uprated fuel pump?
The copper spark plugs won't last as long as the more expensive ones, but they're so cheap I wouldn't mind replacing them every 10k-15k km.
It sounds like you're running factory coils, they're 10+ years old now and wouldn't be working as awesomely as new ones. You can always get new Yellowjacket coils for a very good price. Even if your old coils are working "fine", new ones make a difference (well they did on my car, but mine is turbo).
I can't watch the video loud (at work), but if it's running smoother than before, maybe just drive around for a bit until you can replace the coil packs.
Also, why would you need an aftermarket uprated fuel pump for an N/A?
yep thats probably what im going to do, i found brand new factory ones for only 250 so thats a cheap option as well
i dont need and didnt really want an uprated fuel pump, but it was $ 50 cheaper that a stock replacement and was going to be 2 weeks faster postage so i just went ahead and got it
In a NA they last pretty long. I changed the copper plugs in my Commodore after about 50,000kms only because I was chasing a misfire (which new plugs didn't fix).
^ True, I replace the ones in my R31 every two years lol.
As for those cheap coilpacks, they are fake (there's a post in here somewhere that shows the difference). Hopefully they a few years so it's not a complete waste.
  • 2 months later...
i ended up getting new yellow jacket coil packs and put in new spark plugs also, but my revs are still unsteady and i can feel power dropping in and out when i slowly put my foot down basically im out of ideas as to what it could be, any more suggestions before i get my wallet raped by a mechanic
Lets look at this logically for a second.
We have ruled out spark - new coils and plugs mean it cannot be them.
I wouldn't go so far as to say fuel could be the issue, as it is not at high RPM range.
Maybe the AFM? I would say it is a tune/ecm related issue. I'm not sure how AI based the computer is - I mean does it change the tune depending on how the motor is running? I only say this because I had a friend who dropped a 25neo into his 32, it ran like crap for a week - spluttering, maxing boost at 4psi, etc. As it was his only car he kept driving it. Then one day something just clicked - boom - perfect tune and 12psi.
What I am getting at is maybe because you were running f**ked coils and plug for a while, the computer has compensated and is now giving you this flat spot - maybe running rich/lean. I'm not saying run it and see, but maybe hooking a computer up to the ECM may yield some results, and may just need a flash.
im pretty sure i can rule out the AFM, i checked it and got a mate whos a mechanic to check it again for me,
but the computer trying to compensate sounds like something it could be
since ive changed the spark plugs and coilpacks ive only done around 100 km's the first drive was fairly smooth, second drive i could tell straight away the problem was still there and then the most recent drive was the worst, i cant cruse in any gear but 5th above 3k revs with out the revs jumping and that was when i could notice the power dropping in and out as i would accelerate. the issue definitely seems worse when the car is cold.
but yeah i will get it into my mechanics asap and see if they can get anything out of their computer and ill see if they can reflash it
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
