Brand new - This ignition system will allow you to run much higher spark plug gaps under high boost without spark blowout. This will give more power due to a cleaner burn and give a much better idle and low down power. Includes harness for S13/S14 for straight plug and play and universal harness for other cars.
Part Number: 43001-AK001
Price: $500
Preferred Contact: PM or Reply here
Reason for Sale: Sold car before got chance to install.
The HKS Twin Power ignition amplifier incorporates both the CDI and transistor method ignition to provide optimum spark duration and maximum voltage output, resulting in crisper throttle response and a smoother engine power band. The CDI method, capacity discharge ignition, provides maximum voltage by transferring all stored energy in the capacitor to the ignition coil so that the ignition current can build-up quickly, thus making the Twin Power very effective in the higher revs where a normal spark would tend to diminish. This strong rapid spark prevents the high rpm ignition miss that reduces peak power.
The transistorized method generates high voltage by using transistors to cut off current to the coil, thus allowing for a long energy discharge. This longer spark duration allows the Twin Power to improve lower RPM throttle response and torque. The combination of the CDI and the transistor method incorporates two distinct systems into one high performance unit, hence the designation of Twin Power. Expect a spark output that is typically 1.5-2.5 stronger than that of the stock ignition system! Each compact and attractive Twin power unit is constructed of durable anodized aluminium and sealed to prevent corrosion from moisture.
Edited by stealth923
