Hi Guys,
Just letting everyone know my Skyline was attempted stolen at Westfield North Lakes carpark today around 1pm. Witnesses have come forward and forensics are coming for prints (there are nice ones on the window where they got in)
Now to find a whole new ignition barrel and basically a whole steering assembly as they snapped all plastic and controls.
Hope they get whats coming to them!!!
Also a shout out to William from North Lakes & Districts Towing private tow operator, this guy is a champion call out in 10 minutes and flat rate $88/hr, I recommend this guy for anyone who needs a tow Northside Brisbane.
Here are his details: http://www.truelocal.com.au/business/north-lakes-and-districts-towing/north-lakes
https://www.sau.com.au/forums/topic/427795-attempted-skyline-theft/
Yes alarm system and immobiliser system, saved it cos they couldn't start it, funny thing is they didnt steal the $1000 sound system, GPS, dash cam, prestige personalised plates or any tools that were in the car
Since you are near me pop past. I can sort the column and rekeying the car will be easy as well. Done plenty.
May pay to see if I can steal it as well.
^this right here, if he can make it run/ steal it anyone who knows what they're doing can, lucky break though in the fact they a) didn't get to steal the car and b) didn't pinch anything. Really makes me rethink ownership of a fabulous car all because a few c**ts who obviously can't afford their own want to steal them.
if they tried a basic hot wire would it be possible for me to disable (with remote) the alarm/immobiliser and touch the wires together and it start? unless they have stuffed my immobiliser in the process as my car chirps and central locking is active still?
Edited by GTS R33
Ok I am going to do something I usually do not do..
To take one of these cars for a ride you need to get past the column lock. Hammer or a crowbar is fine for that.
Then you need to get power on . Screwdriver works there once you destroy the key lock you twist to switch and you have a car .
Now if someone has done the job properly the the alarm and paging unit has triggered and the owner is on the way out with a baseball bat. If not the then the alarm wiring gets ripped out and the siren smashed. Then the car is gone.
All of this takes about 3-4 minutes max to do..
Have your attention yet?
I highly recommend you swing past Chris. I attended one of his security nights and it is amazing how fast someone who knows what they are doing can have them started even with a 'professionally' installed alarm/immobiliser.
Depends how the job was done. If it was me, nope. No amount of button pressing would stop the car.
That's no good at all.
By any chance are you a staff member that parks basically in the same spot down the woollies end out the front????
Might be a random question, but whenever I come over to the shop to do groceries etc probably 3 times a week I too always park at that end and there is always the same white 33 in the same spot. Sad to think but if it is you maybe they have been thinking about it for a while.
I got rego make and model of the offenders vehicle, am I allowed to post it on here?
Forensics have come around today and got all the prints and will be running checks. Now I can explore it seems no wires have been cut/stripped, just the ignition barrel and plastics. Maybe the alarm spooked them or they had no real idea what they were doing??? There is so many wires behind steering column its not funny. Westfield is going over footage to get images of car and trace back to people inside. If they have entered the shopping centre they will be on camera.
Depends on what R33 you mean PHT34 - there are a few regulars, i park Woolies area always but not always same spot, prob was me you are thinking of as i havent seen the other regulars for months (maybe theirs have been stolen)
Excel bogans aye. Probably down from depression bay.
Zeke bring it past and I will give it a once over.,
Might swing past next Saturday morning again if that works for you.
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
