Just bought a 2001 300gt and I've searched but still have a few questions.
Done the manifold clean because it had hot starting issues ( it was caked on in there!). Now I have high idle problems. I've tried the reset thingo but still no go. Not sure if I'm doin it right or is there a different sequence for 300's? Just brings up a picture of a spanner and says "pit" on the screen.
Also I've read that 300's don't have vdc bit mine has? Also has a electronic muffler and that sonar cruise control thing. There's a button under the dash near the muffler and vdc controls that says "auto". Anyone know what it does? Small round one.
Please move if not in right section. Cheers
https://www.sau.com.au/forums/topic/427797-v35-issues/
It should work, it works on vq25det motors, which have similar ecus. The timing is the most critical thing, and it must be done when the car is hot.
Pit screen is totally unrelated. Pit screen is just a service reminder scheduled into the on board computer. It requires a manual reset you go through the menus to do.
What do you mean vdc? Traction control?
Auto is probably the rear mirror tilt.
https://www.sau.com.au/forums/topic/427797-v35-issues/#findComment-6909313
Thank mate, guess I'm just a dud then
Ah k at second glance the button has a picture of a side mirror on it so it might be that?
Yea vdc (vehicle dynamic control) I believe it's called. Makes no difference on/off guess maybe in the wet or really flogging it.
Cheers
Edited by OUTATIME
https://www.sau.com.au/forums/topic/427797-v35-issues/#findComment-6909321
No v35 has VDC in the true sense of the modern system.
The rwd models have traction control, which cuts power once rear wheel slip is detected. It does not provide any assistance to gather the car back up into control.
Awd models as in stageas and g35x don't have any systems but the attesa awd system.
Yup, it tilts the side mirro down when in reverse to see the kerb.
https://www.sau.com.au/forums/topic/427797-v35-issues/#findComment-6909330
What do you mean 'true sense'?
The 350GTs have VDC that can brake individual wheels when it detects loss of control based on steering wheel angle, wheel speed and yaw sensor. and it does much more than the basic TC that the 300 and 250GT has which just prevent rear wheel spin due to a heavy right foot.. Although VDC may have been an option on those according to the OP's info.
https://www.sau.com.au/forums/topic/427797-v35-issues/#findComment-6909365
Really? Cool. I thought they only got TC not a proper stability system. RWD stageas only got traction control, no vdc. Which is a bit lacking by 2007.
https://www.sau.com.au/forums/topic/427797-v35-issues/#findComment-6909969
yep, mine gets tested every now and then. There is an off camber roundabout near my house that gets stupidly slippery with the first rain of the wet season.
https://www.sau.com.au/forums/topic/427797-v35-issues/#findComment-6910023
Yeah but even when you turn it off it still keeps the braking/antislip on so if you are used to a car stepping out and tap the brakes the anti slip kicks, or even go round a wet corner under slight brakes it kicks in only braking one caliper... weirdest/worst feeling if you try to correct it like a normal RWD car, almost conterproductive
https://www.sau.com.au/forums/topic/427797-v35-issues/#findComment-6910204
I have heard that a simple 'press-off' will only turn it off up to 60km/h, and there is some other procedure for switching it off for all speeds, something like holding the button in for 10 sec.. never tried it myself, so I can't be sure.
It should turn off VDC and TC. but I don't think it turns off ABS.
https://www.sau.com.au/forums/topic/427797-v35-issues/#findComment-6912148
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
